Nodelink Broken possibly after package update
For unknown reasons my nodlink stopped working correctly. This may coincide with me updating eisy to the latest stuff for the eisy-ui(0.7.1). I am only running DSC Link. Nodelink is talking to the DSC panel, it lists all the partitions status and zone status correctly on its configuration page. The heartbeat from nodelink to ISY is working. But none of the zones are partitions are populating. I tried deleting nodelink from ISY and DSC from nodelink and readding. ISY repopulated all the nodes and partitons in ISY, but does not populate the status of any of these things. I have of course rebooted all three pieces of the euqation. When I attempt to query nodelink from ISY, I get this:
But most everything is unpopulated.
Also, If I try to arm/disarm, activate outputs, I get the same TCP error.
Here are errors in Nodelink.
2025-10-27 09:28:36 - ISY NodeLink Server v0.11.1 started
2025-10-27 09:28:36 - OS: Linux raspberrypi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
2025-10-27 09:28:36 - Installed .NET Runtime Version: 5.0.3
2025-10-27 09:28:36 - Web config server started (http://192.168.1.51:8090)
2025-10-27 09:28:36 - ISY resolved to 192.168.1.9 (6.0.0)
2025-10-27 09:28:36 - ISY Node Server config detected (profile 1)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Dryer motor)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Back Waiting)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Heat pump)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Hot Tub I think)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Back Door)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (LouS22)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Garage Lou)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Garage Ellen)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Coffee Bar Fridge)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Raymond)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Front Door)
2025-10-27 09:28:36 - ISY Warning: Duplicate node names exist on the ISY (Ellen S21)
2025-10-27 09:28:36 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/EDITOR/I_EDIT.XML)
2025-10-27 09:28:36 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/NODEDEF/I_NDEFS.XML)
2025-10-27 09:28:37 - ISY Error: Web Error (FILE_NOT_FOUND) - Forbidden (profiles/family/10/profile/1/download/NLS/EN_US.TXT)
2025-10-27 09:28:37 - Warning: Node definitions need updating in ISY, see NodeLink's Devices page
2025-10-27 11:51:37 - DSC TCP: No poll response, attempting to reconnect to alarm [dsc1]
2025-10-27 11:51:37 - DSC: Reconnecting To Server [dsc1]
2025-10-27 11:51:37 - DSC Error: Data Arrival - Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'. [dsc1]
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1/add/DSC?primary=n001_dsc1&name=DSC Alarm&nls=102D)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_part1/add/DSCPartition?primary=n001_dsc1&name=Partition 1&nls=102DP)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_part2/add/DSCPartition?primary=n001_dsc1&name=Partition 2&nls=102DP)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z01/add/DSCZone?primary=n001_dsc1&name=Zone 01&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z02/add/DSCZone?primary=n001_dsc1&name=Zone 02&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z03/add/DSCZone?primary=n001_dsc1&name=Zone 03&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z04/add/DSCZone?primary=n001_dsc1&name=Zone 04&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z05/add/DSCZone?primary=n001_dsc1&name=Zone 05&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z06/add/DSCZone?primary=n001_dsc1&name=Zone 06&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z07/add/DSCZone?primary=n001_dsc1&name=Zone 07&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z08/add/DSCZone?primary=n001_dsc1&name=Zone 08&nls=102Z)
2025-10-27 11:58:44 - ISY Error: Web Error (NODE_ALREADY_EXISTS) - BadRequest (ns/1/nodes/n001_dsc1_z09/add/DSCZone?primary=n001_dsc1&name=Zone 09&nls=102Z)
@bmercier @io_guy
EDIT: Some stuff is sporadically populating, like I armed and disarmed and it says disarmed, but all the other fields are still blank. But I can not do anything from ISY to the alarm without getting the TCP error pictured above. Arm/Disarm/Activate outputs/Query all give me that error.
EDIT 2:
Just to be complete, here is the DSC device page on Nodelink listing all the zones and alarm partition info with all the spots filled in.
Edited by apostolakisl
I believe I have the same issue as @sorka Not exactly sure the process of fixing it as playing with rpi like this is not my forte. But I see the same problems as he described in my setup. I don't understand how it worked fine for all these years and out of the blue there are issues. I also don't have the installation files for nodelink.
  • 2 months later...
Unfortunately there's not much I can do to support changes caused by EISY firmware. I don't own a UDI device anymore so I have nothing to try and reproduce/debug on.
I have nodelink also running on a second Polisy running the same firmware without Issue. So I'm not sure it is related to the firmware.
