3 hours ago3 hr Before I send the old ISY to the recycle, is there a group of curmudgeons that refuses to give up on old tech and would be interested in the ISY?It's a 994i ZW+. The power light flickers/doesn't work, but the unit functions properly in all other respects. I did open the case once to see if there was an obvious reason why the power LED wasn't working, but since the unit worked OK, I closed the case and let it be. (Tried a new power supply, same result) Factory reset will be performed. No SD card.Free to a good home.
