Local Connection getting "Invalid Credential" 401
In UD Mobile (android, version 1.4.6) when I attempt to access Settings / Plugins I am getting this error message: "could not get pg3 auth Invalid Credential. Please check username and password. 401"
This is an eisy running IoX 6.0.0_4 and eisyui 0.7.2
UD Mobile Local Connection Settings:
Local IP Address: http://Numeric_IP_address
Local Port: 80
Local Username: ISY Portal Username
Local Password: ISY Portal Password
Edited by wmcneil
correct typo
Solved by Javi
So if I change local connection settings to use port 8080 and the "IoX" credentials (instead of the ISY Portal credentials), the problem goes away. @Javi , I assume UD Mobile will eventually fix this and support ISY Portal credentials on port 80, since not doing so would make UD Mobile inconsistent with all the other interfaces?
