HDMI screens not working
I have not been using the HDMI screens and only recently reattached them and now I see nothing on them. when it reboots I do not see the boot sequence. The screens indicate the HDMI port is not connected.
I was using them for my initial configuration and only recently went back to add more devices, scenes and some actions but now I cannot get the screens to be active. It appears to be working as I can get to it through the UDmobile interface and it appears to be responding to commands. I rarely use the mobile interface (I prefer a standalone insteon home without me haveing to remotely control it) so I do not know for sure it is working but it does respond to selections.
What do I do to get the HDMI interface back?.
Solved by S. Alexei Gitter
If you press the F7 key repeatedly while powering up, does anything come up on the screen? If not, try power cycling the monitor first, then powering up the eisy again.
argh ... something odd with that pair of monitors ... I used another pair and these worked.
The pair that wouldn't work are standard 1920x1280 and the pair that does are 2560x1440 ... I believe I was using the low(er)-res pair when I was on the EISY earlier but perhaps not. They seem to be having trouble on other systems now too ... double argh.
Sorry for the alert, Should have tried the easy solution first. Thank-you
