Help with Denon AVR
I have a Denon AVR-X2200W. I installed AVRemote and added the Denon in the "Custom Typed Configuration Parameters" section. I put the static ip address of the AVR in as the host name.
In the Admin Console it shows "Denon AVR Online" as 'True'.
The volume, power, and mute statuses seem to be right and updating. But the input always sits at 'tv_sat' and the unit does not respond to input changes in the Admin Console.
I have tried changing 'Connect on demand' from the default 'false' to 'true' with no noticeable change. What does this parameter do?
If the volume, power and mute status is correct, I am at a loss as to how to get the input to show the correct status and unfortunately that is the main data point I wanted to use. Any suggestions would be appreciated.
Put node server into debug mode, generate log package and PM to me. I'd like to see both, you changing source using remote, as well as trying to change it via AC. Please, write down the time for both.
"Connect on demand" is a workaround where some models do not function with permanently opened telnet connection. So it's opened at the time node server reads or writes.
