Just upgraded to 6.0.4
I had been holding off on upgrading my in-service eisy, which was still on 5.9.1. After testing 6.0.0. and 6.0.3 on a test Polisy, and seeing that the release notes in the sysconfig.txt file indicated only minor fixes for 6.0.4, I concluded that the new version must be stable enough to give it a go. So with lots of trepidation (and a couple of prayers) I went ahead and launched the upgrade. Of course, doing this on a day like Christmas would usually be quite foolhardy, with no UDI support readily available. But I have a eisy recovery image on a USB all set, and a screen and keyboard at the ready. So I started by doing a full cpio backup of my entire eisy to a USB drive first.
In a nutshell, it worked out ok. I had to manually add the eisy back to IoX finder before I could see it. I added both lines for the IoX and portal logins. Then I took a quick tour of my system. Insteon was Insteoning, Zwave was Zwaving. Plugins seemed to be up and running ok. The only thing not quite working is eisy-ui, which isn't critical for me at this time. I indicated that in the appropriate forum section.
I guess getting an updated recovery image would be a good next step, to keep my first aid kit up to date.
Glad it worked for you! I also had no issues on two production EISY units. I did also manually add the local access to the finder so I didn’t have to use the portal credentials for the ones that it found automatically. One thing I noticed a couple days later was a polyglot node not updating the node correctly, So I ended up restarting everything and it cleaned up just fine.
