Tapo TP-Link TP15 Matter
I have been unable to add the TP15 directly to Eisy using Matter.  When I try I get UD mobile to scan the QR code but it never completes the configuration.  This it with the current beta Matter, UDMobile 1.5.2.  I have also tried using the Matter code with the same results.
The work-around that I have found is to use an Echo (gen 4 to serve as a “thread border router”.  There are several Alexa devices that will do this.  Here is a detailed procedure, sorry to the experts for the step-by-step but I want to make it clear for anyone.
First do NOT configure the TP15 through the Tapo app.  It will connect fine to the Echo but you can’t get a forwarding code from Alexa.  If you have it installed in Tapo, just delete it and do a reset.
Plug the TP15 into an outlet.  Open the Alexa app – go to Devices, +, Add Device, other, Matter and follow the instructions (note, don’t use the default Alexa install for the TP15.  I expect it installs with another protocol instead of Matter).  Once the device is found you can name it for use with your echo (name doesn’t carry over to UD).  Now in the Alexa app select the TP15 device, settings (gear icon), Other Assistants and Apps, add another (+), copy the set-up code to the clipboard or write it down.
Open UD Mobile, settings (gear icon bottom right), Matter, add (+), paste or enter the code (hyphens not required), submit.  It took a while so be patient.  Accept the synchronize pop-up.  The new device will appear as ZM XXX.1 On-Off Switch.  Tap on it to change the name and save (it won’t show the new name yet).
Open Admin Console – Matter tab, synchronize, new & deleted, yes.  It will appear with the new name.  You can now move it into a folder, add it to scenes & programs as it is now a fully integrated node.
Go back to UD Mobile and synchronize.  The name will update.
This may work with other TP-Link devices but the TP15 is the only one that I have to test with.  I hope this helps someone get through this much easier than it was for me.  I’m sure UD will fix the direct connect before Matter goes to full release.
Edited by BobMic
Correction Echo "dot" nor a border router, thred support only.
What you've discovered is that at this point, eisy isn't very good at configuring (commissioning) a new Matter device, but it's becoming better at accepting a shared Matter device from another platform, like Alexa or Google home. That's how we mainly do it at this time. It's still in Alpha testing on the eisy.
Thanks Guy. I got that tip from a thread that I found but there was no detail so wanted to make the step-by-step to save new comers the 3-4 hours that it took me to get the sequence and details correct. I'm new to Matter and also Alexa. I have been using isy and Insteon for many years but it was a bit fiddly.
Another thing you mention in your original post: an echo dot isn't a border router. Matter uses IPv6 for it's communications with devices, implemented over traditional ethernet/wifi, and also over Zigbee ("Thread" devices). A border router will bridge the two topologies. Here is a list of the devices that have that functionality:
https://www.matteralpha.com/frequently-asked-questions/complete-list-thread-border-routers
Thanks for pointing that out and directing me to some good information. I'm new to Alexa, had a dot sitting around for a couple of years still in the box. A web search led me to the fact that several echo devices will work as a threads border router. I tried the dot g2 which of course didn't work but got me interested in Alexa. I bought an "Echo g4" which I wrongly assumed was the current "Dot". I have edited my original post to correct that.
  • 3 weeks later...
I have been working with Javier on this. He informed me that after making the connection via Alexa (and probably others), generating a setup code and connecting to eisy, the device can be deleted from Alexa. UDM and eisy will still have full control and rights to the device. Of course if the device requires a "thread" connection you will still need it configured in your Alexa or other Thread Border Router as eisy does not have that capability yet. The TP15 does not require a thread connection so works fine.
To my knowledge, the border router is "transparent" to the network. Any given controller (Alexa, eisy, Google home, etc) doesn't know if a device is Thread or ethernet. Once it knows about a device, it simply talks to it using IPv6, which gets routed over the router if needed.
Edited by Guy Lavoie
When you say "gets routed over the router" are you talking about my network router or the border router? I looked at my router and all three devices are on the IPv4 list, none on the v6 list. I don't have any devices that require thread.
I mean border router. The purpose of the border router is to bridge the two transport (layer) methods: ethernet/wifi, and zigbee (which Thread uses). The network layer is always IPv6. I don’t yet know how the border router "knows" what IPv6 traffic to route or not. There must be a scheme to that, more stuff to learn. Border routers have no configuration options, they just "do it". When UDI first implemented Matter, they had to implement IPv6 on the eisy and Polisy. It's still in development. As it currently stands, talking to a Thread device needs a border router because only the network interface is used. Ultimately, they'll hopefully implement talking to the zigbee (Thread) devices directly through the Zmatter dongle. Maybe the eisy could become a border router itself.
Starting to make more sense to me now, thanks! I wasn't thinking about thread as being a radio path separate from WiFi. I haven"t used any Zigbee devices so the light (in my head) just didn't go on. I just did some reading on Zigbee transport protocol and network stack. For sure the devices that I'm using (TP15) is a WiFi 802.11 device with Bluetooth commissioning. No need for thread which is what I guessed but didn't completely understand why...until now.
Yes. Matter didn't really invent anything new. It uses existing technologies (IPv6 for networking, wifi/ethernet, and also zigbee for low power applications). The only real innovation is transmitting IPv6 over zigbee. It cuts down development costs. It's mostly software, for sharing devices across platforms. One other thing that UDI also hasn't implemented yet is device sharing. It accepts shares, but doesn't yet provide sharing to others. That's why you might want to keep the device configured on another platform like Alexa for now, If it exists only on your eisy and you'd want to share it to something else, you'd need to delete it, recommission it, reshare, etc.
I've found only one sequence that works for me to add Tapo TP-Link devices to EISY Matter...
  1. In the Apple Home app, add the device by scanning the barcode on the device (or entering that Matter ID).
  2. After the device is added, named, and ready in the Apple Home app, long-tap on the device tile until the context menu displays, then choose Accessory Settings.
  3. Scroll to the bottom of the settings list and choose Turn On Pairing Mode.
  4. Get the pairing setup code on your clipboard with Copy Code.
  5. Open the UD Mobile app, choose + and then Add Matter Device.
  6. Paste the setup code and follow the UD Mobile process.
I found that if I take too long doing steps 2 through 5, the UD Mobile pairing fails. I don't know why, but I'm guessing that by then some other meddling system (Alexa, I suspect) is doing things I haven't asked it to do. I don't need to rush those steps, but I start them as soon as I've completed step 1.
If I want to change the ramp rate for a dimmer device, I need to do that in the Tapo app. But only after all of the above! Adding the device to the Tapo app before getting Matter going in EISY always leads to failure for me.
In the Tapo app, to change ramp rate, add the device, open the device settings, then look for Lights On/Off Gradually.
Matter works -- it's just a bit like the power management sequence for restarting the command module in Apollo 13. One wrong move and you have to start over.
  • 5 months later...
It has been a few months since this last post and I was wondering if there has been any updates in the Matter support. To this point I tried to install a TP-Link KP125MP plugin using the UD Mobile. It started real good and then during the process to connect the Matter device to the controller it failed with a message the matter commissioning service could be found.
On the other hand, last week I added a Gledopto RGBCCT LED Strip controller and it picked it right up! Great job Javier! If I can now just figure out the logic behind setting colors using HSV instead of RGB.
