January 13Jan 13 I've used this plugin for a long time, and it's been super-reliable. BUT recently - possibly after a recent Eisy upgrade - the plug-in has been working perfectly only after it is restarted. At some point after it is restarted, it seems to hang. One crisp symptom is that the 'Update' button works flawlessly after the plugin is restarted, but then a short while later (usually less than an hour), when you click on 'Update' you get a "TCP client read response failed" error. My system is on the latest production version of everything, and I've tried deleting the plugin and reinstalling it in a new slot.Something must be corrupting the plugin? Any ideas as to what might be causing this?I love this plugin, in part because it's the only plugin that lets you directly set a specific listening mode (e.g. Dolby Atmos).
January 14Jan 14 It's possible that the plugin isn't compatible with the latest isy firmware release. The author isn't on the forum so there's no way to reach him.Take a look at github: Repository search results · GitHuband GitHub - TangoWhiskey1/OnkyoAvrNodeserver: Onkyo/Pioneer AVR Node Server for Polyglot V2The author is TangoWhiskey1. It looks like he hasn't updated the node server in quite awhile as it was written for PG2
January 14Jan 14 I believe I ported that from PG2 to PG3.To debug, set the logging level to debug, restart the plug-in and the next time you notice it has hung, download the log and either attach it here are send it to me in a PM. The log does clear and start over at midnight so if it hangs on a Tuesday and you don't notice till Wednesday, the Wednesday log won't show what caused it to hang.
January 16Jan 16 Author Bob, thank you so much. An unexpected result. An hour after seeing your post, I set the logging level to debug, and restarted the plug-in. Things ran flawlessly for almost 2 days, which was weird because it had not gone that long in recent times. So an hour ago I set the logging level to 'info' and restarted the plug-in. Ten minutes later I once again had the error that I posted above. I guess the good news is that I now have a work-around, i.e. keep the logging level set to 'debug'. Any thoughts? Thanks again for offering to help -Barry
January 16Jan 16 That's kind of the opposite of what I would expect. Setting debug just makes the plug-in add more messages to it's log. Possibly it's a timing issue, but the error you're seeing indicates that when IoX sends the command to the plug-in, the plug-in never acknowledges it.If the plug-in is crashing, even the log when it's set to 'Info' should provide some information.
January 26Jan 26 Author On 1/16/2026 at 8:51 AM, bpwwer said:That's kind of the opposite of what I would expect. Setting debug just makes the plug-in add more messages to it's log.Possibly it's a timing issue, but the error you're seeing indicates that when IoX sends the command to the plug-in, the plug-in never acknowledges it.If the plug-in is crashing, even the log when it's set to 'Info' should provide some information.@bpwwer I set the log back to 'info' 10 days ago, and things have been working flawlessly since then. In other words, when I first posted I had an issue that was easy to reproduce, and now I don't have the issue at all. Something else (other than the log setting) that I changed 10-12 days ago must be at play. I did clean up some code that had been hitting the plug-in a few times in quick succession. Possibly my old code was causing a timing issue as you suggested., If I run into the issue in the future, I'll try adding a short 'wait' in between calls. Meanwhile, for now the issue is closed.Thank you again for your help!!
