Mini Remote Flashes Red When Charging
Hi. The charging LED flashes red while charging. I charged for several hours but it kept flashing. I thought it was supposed to be solid red while charging and go off when charging complete. Not sure if it’s fully charged but it works. Do you think there is an issue with it?
Charge LED on the lower right side inside the case. On mine near the USB charging port. Is solid red when charging and turn off when charged.
Is this a newly purchased remote? I doubt they changed the way it works. Maybe see what other have found for a better understanding if it is changed or defective.
