Camect nodes update but programs don’t trigger
System:
- Work system: eisy / IoX 6.0.4 / PG3x 3.4.13
- Home system: PG3x 3.4.11 works correctly
- Camect plugin version: 3.1.0
- Status in PG3x: Connected
Problem:
Camect alerts are visible in the Camect UI and the PG3x log shows successful updates to IoX, but ISY/IoX programs are not triggering on the work system.
What I already tested:
- Removed and reinstalled the Camect plugin
- Confirmed alerts appear in Camect
- Confirmed PG3x shows node updates such as GPV and ST changing
- PG3x log shows “Successfully set ...” for Camect nodes
- This same setup works at home on PG3x 3.4.11
Why I suspect PG3x:
The main difference I can see is PG3x version:
- Home: 3.4.11 works
- Work: 3.4.13 does not trigger programs
Question:
Has anything changed in PG3x 3.4.13 that could affect Camect node event/status handling in IoX programs after reinstall?
Also, should Camect programs be triggered using STATUS, CONTROL, GPV, or another driver on current versions?
Examples from log:
- Host:update_status: cams=True report=True
- Successfully set 01_004 :: GPV to 1
- Successfully set 01_004 :: GPV to 0
- Successfully set 01_003 :: GPV to 1
- Successfully set 01_003 :: GPV to 0
Quick update: today the Camect nodes are triggering IoX programs again.
Nothing was changed on the system since yesterday (still PG3x 3.4.13), so it may have been related to the node server reinstall or IoX needing time to rebuild program event subscriptions.
I'll keep monitoring it, but for now everything appears to be working normally again. Thanks for taking a look.
