March 17Mar 17 I have 2 separate EISY's (running 6.05) at 2 locations. My wife and I both have UD mobile and still have Mobilinc Pro (for ibeacons). I have set up geofences using Occupancy for both of us. Recently, I have noticed that while my geofence reporting and ibeacon responses are good, hers are not (that is, not reporting). I have spent quite a bit of time making sure that the URL's in Occupancy are accurate, the UUID's, etc in beacons are accurate and have made sure her phone (iPhone 17) has the correct settings for location always on, etc. All to no avail. Should she have separate login credentials at UD mobile and at the Portal? Would this make a difference? Right now, her UD mobile app uses my login credentials.
March 18Mar 18 Author The following (not sure which) solved the problem:Under location services/system services toggle on/off significant locationsDisable Focus mode
