1 hour ago1 hr I've just installed a Elk M1 and I'm exploring this plugin. Wow, it really has everything! Probably the most complete plugin there is. With my Elk installation still being new, I'm often going back into ELKRP to look at or tweak something. Because there is only one access port on the M1, this means going into polyglot, stopping the plugin, doing what I need in ELKRP, and then starting up the plugin again. Is there a trick or workaround that would simply suspend the plugin temporarily from accessing the M1, from within admin console, which would release the access port until I tell it to resume? It would be handy and quick. If not, would this be a handy feature to add?
