April 12Apr 12 With Alexa+, if I say dim or brighten an Insteon scene it works. If I say "Alexa, Set scene to 49%" it turns it to 0% and if I say "Alexa, set scene to 50%" it turns it to 100%. That seems like odd being that both dim and brighten allow me to get to in between levels, I just can't go directly to the brightness I want. Setting levels directly works with Hue and I swore it used to work with EISY/Insteon scenes.
April 12Apr 12 I ran across the same thing a year or two ago. I believe what I changed the designation of the spoken command to device instead of scene or scene instead of device and that room care of it. I'm not a hundred percent sure, but it's worth a shot.
April 14Apr 14 Author On 4/12/2026 at 6:28 AM, lgilsenberg said:I ran across the same thing a year or two ago. I believe what I changed the designation of the spoken command to device instead of scene or scene instead of device and that room care of it. I'm not a hundred percent sure, but it's worth a shot.To get the brighten/dim to work, I already have the alexa category set to "device/light", setting the category to "scene" seems to ignore everything but on/off. Set room to 50% still gets me 100%. Weird and annoying.
