odd behavior
Help:
I've got the following program which is not acting right...
IF
status GAR KPL H IS ON
or status MBR KPL H IS ON
or status APPLIANCE LINC IS ON
and FROM SUNSET
to 10:35PM (SAME DAY)
and GARAGE CLOCK APPLIANCE LINC IS OFF
THEN SET GARAGE CLOCK APPLIANCE LINC ON
This seems to work during the time sunset to 10:35, but after 10:35 is shows a "TRUE" and will not turn off. I've tried anothe appliancelinc, same result. I have an inlinelinc that has an identical program and does it perfectly. It also shows "FALSE"? What am I doing wrong?
Chris: Thanks. It works! Could you explain what the () do? Again thanks.
TIm
Chris:
When sunset came around today the items fired, but they flashed on and off, on and off. I had to remove the call for else.
Take the Christmas lights. The program was:
From sunset
To 10:30PM
IF Gate outlet is OFF
Then Gate outlet ON
ELSE Gate outlet OFF
I would think that any time the gate outlet was turned on away from sunset to 10:30PM the program would turn it off. It did just that. But at sunset the gate outlet flashed on and off as the GUI showed the same. I removed the ELSE and the flashing stopped. I'll look tonihjt after 10:30 and see if, #1 it turned out and #2 if I try and turn it on, will ISY turn it out?
What did I do wrong with my program? I must be missing something in the syntax. I'm still struggling with the logic of the ( ) issues as well. I'm not sure why the TRUE FALSES change with ( ).
Tim
Chris:
To clarify my questions on ( ), In the case I stated last night, I needed all the "or's" and all the "and's" to be TRUE, herefore, I'm not sure why the ( ) helped differentiate the call as true or false?
Tim
Looking at your example, doesn't the state of gate determine if the program is true and therefore cause it to flip back and forth? What if you get rid of the else statement?
ON PROGRAM:
From sunset
To 10:30PM
Then Gate outlet ON
ELSE do nothing
OFF PROGRAM:
From sunset
To 10:30PM
IF Gate outlet is ON
Then do nothing
Thanks upstate. I'll try it.
Tim
Chris:
Tim
I think you need the group of Or's to be true right? In other words at least one them being true. Otherwise in this case, you'd just use AND for every thing.
