6 hours ago6 hr I bought a used ISY994i ZW IR PRO for a backup and in attempting to test the IR the admin console says IR configuration not valid when I attempt to load default IR values. I have an IR.cfg from an ISY99i that is just XML with <ir> tags. Is it possible to just add that to zip file? Or is there a cleaner option? Also I bought a couple of IR daughter boards from UDI years ago as backups but didn't purchase IR module upgrades. Is the IR.cfg all that is needed? I'm assuming this sort of information is covered under "Right to Repair" law. Edited 6 hours ago6 hr by universal1
