DysonFan v5.2.0 released
DysonFan replaces DysonPureCool since more devices are now supported. I'm assured that the licensing will transfer over since the NSID hasn't changed, only the name. Support has been added for the HushJet HJ10 series. TP02 and PH02 support are still experimental.
The name change will probably require you to delete your current plugin from its existing slot and then re-install. Be sure to have your configuration information on hand before deleting the old one.
