Temperature with ZSE70 Zooz Outdoor Motion Sensor?
Hi All.
ANYONE out there with a Zooz ZSE70 able to view and use the Temperature data it is supposed to send? None of my nodes for it show Temperature but it is one of the main advertised features of this sensor and one that I want to use. ANY feedback appreciated.
I am currently on v5.8.4 on a Polisy but have an eISY for spare that I will eventually move to - I will move to it sooner if someone tells me that it will enable seeing & using Temperature from this sensor.
Shawn
I have an EISY with 6.0.5 firmware and the ZSE70 shows the temperature.
You should probably try updating your Polisy/Eisy firmware
Do you remember when you installed your ZSE70? Or, do you remember what level you were at when you installed it?
Thank you, but correct me if I'm wrong - the next version after mine (5.8.4) had a good chance of bricking your Polisy, right? (no prob for eSIY)
Also, I thought not long after that they stopped Polisy from getting new versions before the v6.0.0 arrived?
It's best to open a support ticket before you try to upgrade your Polisy . See the link below
Updated Software Available! - Current Release Announcements - Universal Devices Forum
You'll want to have the lastest firmware versions on your Polisy and EISY before you migrate from the Polisy to the EISY
Do you have the UDI Zwave/Matter board on both the Polisy and Te EISY?
Yes, I have a new ZMatter-USB to replace the ZMatter-Internal in my Polisy. My eISY has not been out of the box yet so will have at least 1-year old+ firmware. That's a bit of a kenundrum - how do I migrate if I can't safely update the Polisy. But that is smart, I will open a ticket for that.
Thanks for that recommendation. I take it you are unable to answer my other 2 questions about your ZSE70 installs?
I also have a ZSE70 installed on eisy 6.0.5 with the ZMatter board and it shows temperature
