July 5Jul 5 My Hue Emulator node server no longer has any entries in its Spoken Device Table. I have attached the log, and provided a snipet below. The messages indicate that the node server is not able to communicate with the eisy. A couple of days ago I updated from IoX 6.0.4 to 6.0.5, but I'm not absolutely certain whether the problem with the Hue Emulator started at that point, or possibly at some earlier point. Here are the exact versions of everything as reported in eisy-ui:IoX 6.0.5_10UDX 4.5.0_7PG3x 3.4.19eisy UI 1.0.9Matter Bridge 1.3.24mosquitto 2.0.18libwebsockets 4.3.32026-07-05 00:00:02.139 Thread-23579 (handler_poll) udi_interface ERROR Controller:shortPoll: Thread is dead, restarting.2026-07-05 00:00:02.608 ConnectISY udi_interface WARNING Controller:set_listen: Set to 12026-07-05 00:00:02.609 ConnectISY pyisy ERROR connection:request: ISY Could not receive response from device because of a network issue.2026-07-05 00:00:02.610 ConnectISY pyisy ERROR isy:__init__: PyISY could not connect to the ISY controller with the provided attributes.2026-07-05 00:00:02.610 ConnectISY ISYHueEmu ERROR ISYHueEmu:connect: ISY not connected, will try again2026-07-05 00:00:02.696 Thread-23580 (handler_poll) udi_interface WARNING Controller:longPoll: Listen Count = 5 HueEmulator_7-5-2026_101052_AM.zip
July 6Jul 6 Author Solution I figured it out - as is frequently the case, it's a dumb mistake - numeric IP address was off by 1.
