July 5Jul 5 In hope of reconnecting my Honeywell T10 thermostat, I downloaded the trial version of HomeKitHub professional. It appeared to download, but showed as a big red "disconnected" and running discovery did not find the thermostat.
July 5Jul 5 Did you do this as mentioned on the announcement post? Please make sure you have done a recent Upgrade Packages: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#common-causesIf so, review: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#discover-does-nothing-or-adds-no-rows
July 6Jul 6 Author On 7/5/2026 at 4:34 PM, Jimbo.Automates said:Did you do this as mentioned on the announcement post? Please make sure you have done a recent Upgrade Packages: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#common-causesIf so, review: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#discover-does-nothing-or-adds-no-rowsOK. It is now "connected". Discover did not find the Honeywell T10 thermostat. I manually added the eight-digit HomeKit code and this did not work, either. I am wondering if the prior pairing with the Honeywell node server is interfering with the discovery process. I may fool around a bit more with it.
July 6Jul 6 18 minutes ago, oberkc said:OK. It is now "connected". Discover did not find the Honeywell T10 thermostat. I manually added the eight-digit HomeKit code and this did not work, either. I am wondering if the prior pairing with the Honeywell node server is interfering with the discovery process. I may fool around a bit more with it.Are you running the lastest HomeKitHub Version 2.0.14? That one had some improvements to the code which helped another user find their device.and there are some other issues mentioned here: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#d-accessory-not-visible-on-the-lan-mdns
July 6Jul 6 51 minutes ago, oberkc said:OK. It is now "connected". Discover did not find the Honeywell T10 thermostat. I manually added the eight-digit HomeKit code and this did not work, either. I am wondering if the prior pairing with the Honeywell node server is interfering with the discovery process. I may fool around a bit more with it.Just released 2.0.15 which has more improvements on searching for devices...
July 7Jul 7 Author 3 hours ago, Jimbo.Automates said:Are you running the lastest HomeKitHub Version 2.0.14?Yes.3 hours ago, Jimbo.Automates said:Just released 2.0.15 which has more improvements on searching for devicesPerhaps I will try it. Edit: 2.0.15 appears available only for the standard version. Since I thought I needed the pro to do what I wanted (Honeywell T10) thermostat) I did not try the standard version.12 hours ago, Jimbo.Automates said:and there are some other issues mentioned here: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#d-accessory-not-visible-on-the-lan-mdnsYes, I read this. Unfortunately, it uses terms and expressions that have no meaning to me (for example: Run Zeroconf diagnostic on the controller!!??), and I am still trying to decide if the amount of time that I would have to spend to understand this is make it work is the something that I want to expend. My system is feeling pretty fragile as it is (the matter devices I have fail regularly and a zwave lock loses function) and I am already spending too much time keeping it running.Thanks for the advice so far. I will let you know if I progress any further. Edited July 7Jul 7 by oberkc
