Scenes and brightness levels
I've had a boatload of issues with backlighting and today one thing led to another and many switches needed to be reset. I reset them to factory and then reloaded them into the eisy. A single lone switch was Ok , but scenes were all in need of reprogramming. I got the main backbone done, then I noticed that the scenes when triggered by a KPL button were not setting SWL's t the proper level. Can someone tell me how to program the ramp rates and brightness for each SWL in a scene. Also I thought by simply entering ramp/brightness in a SWL would tell the switch how to perform when the switch rather than a KPL button was pushed.
Let me try and elaborate.
I have a scene, "NIGHT" which I push button "F" and the scene has a half dozen SWL's in it. Some dimmers, some just switches. I have set the ramp and % brightness in the scene under each unit. I push the button and they all go to rogue settings.
In addition I have a dimmer mated with a KPL button that when the button is pushed would likely go to 33%. It goes full bright even though I have the level set to 33%.
I know I'm missing something simple
