Node Discovery Problem
I recently added a FlowSmart All-in-One (YS5018-UC) and am having problems with node discovery on the YoLink plugin. I don't know if the two are related, but I have 70+ YoLink devices and the FlowSmart refused to be discovered. I've since deleted and reinstalled the plugin (many times) and it only discovers 31 devices. Never any more.
Here's some of the details:
  • PG3x Version: 3.4.19
  • IoX Version: 6.0.5
  • YoLink Version: 1.8.60
I did a fresh install and captured a debug log of the discovery (attached to this post), but I'm not familiar enough w/ the app to spot where things went wrong. Any suggestions on where to look for problems or what to do next would be appreciated.
Ron
2026-08-04.debug.log
you need to make sure the Flowsmart is online when you start the node. it goes into a deep sleep mode where you cannot communicate with it. Try to press the set-button before starting the node
Thx for the suggestion.
The Flowsmart is actually pretty hard to gain physical access to -- it is in a crawlspace and takes a while to reach. I'm not sure how long it takes to drop back into a deep sleep, but it may do so between the time that I press the button and when I get back to the computer to restart the plugin.
As an alternative, I checked the Flowsmart status via the YoLink smartphone app and then restarted the plugin. Presumably the Flowsmart is awake and online when it is talking to the app and hopefully stays awake long enough for the discovery process to run. In doing this the Flowsmart was still not discovered nor were the 40+ other "missing" YoLink devices in the environment.
While I'd obviously like to get the Flowsmart integrated into my overall home automation system, the real pain point right now are the other 40+ devices that have gone missing. Are there any hints in the debug log that might suggest why they aren't discovered? If something points to the FlowSmart somehow breaking the overall discovery process then I'll delete it from the YoLink environment and re-run discovery, but that is moderately difficult to do. While I'm quite willing to do this, it would be nice to have some specific log messages suggesting that this would be helpful.
Again, thanks for your help with this. The YoLink plugin has been incredibly useful and I've come to rely on it quite heavily, so I appreciate your assistance in getting it back on line.
If you can control the valve in the app it should be ok to register (start the node) - you can also try to contact yosmart (service@yosmart.com) to see if there is a newer firmware - I know they are working on addressing the deep sleep issue - do you see an option in the app to select mode
There is nothing obvious in the log - a few devices report offline (0201) but it does not look like overload on during start up - they should come eventually as code will keep trying to poll devices that have not already reported data - no errors reported in what you send
