August 29Aug 29 I’m considering replacing my pC1864 panel with Eyez-On Uno panel. Has anyone done this and how did replacement go? Also, did it work well with this plugin. I assume it would given they both use the EVL interface from Eyez-On..
August 30Aug 30 The EnvisaLink EVLs had two different APIs (EnvisaLink calls them “Third-party Interfaces” or “TPIs”), one for DSC panels and one for Honeywell/Ademco panels. The UNO added a third TPI so you just can’t point the EnvisaLink plugin at an UNO and expect it to work. That said the UNO TPI is more similar to the DSC TPI, so that’s where I would start.
August 30Aug 30 Author Thanks. Is adding that tpi something you would consider doing? I’m assuming it would be a third plugin based on the EVL?
August 30Aug 30 Author Thanks. If I get more serious about it and you will do it, I’ll be the tester. Hypothetically, any chance it could overlap the DSC version so I could install it in same slot to retain devices etc and not have to rework a bunch of programming?
