58 minutes ago58 min Just put up to beta v0.0.25 with a feature request from @Techman Added a field called Last Command Executed which upon startup is populated with None then moves to {Open, Close, Stop, or My Position} based on the command given.Note that if the RTS shade is moved manually with the remote or even from the Tahoma app, there is no feedback here, this is purely as a memory for your programs ; careful as you use it.Feedback welcome as we tweak this plugin.## 0.0.25- Shade Last Command Executed (GV8): new status alongside Last Command (GV7); reports Open, Close, Stop, or My Position when sent; starts as None on node startup; GV7 still tracks Pending / Completed / Failed from the gateway
44 minutes ago44 min Nice. Did you give some thought to the timed open/close, to allow a command to open or close a certain percentage?
