September 13Sep 13 so this is back office but what it does for eisy-ui is make updates to the node list happen immediately, instead of getting stuck when you add/remove nodes or install a new version of the plugin in the same slot. It works pretty slick and is the modern way to handle profiles as we move away from the admin to eisy-ui. My only worry is you can see below you have to be decently up to date on your controller, which is not the case for everyone out there.Interested in feedback here. You can install this either from the old non-production store or it shows up as a beta trial (1-year trial) if you install from the new eisy-ui plugins(beta). 3.2.2 \DONE dynamic JSON profiles (Phase 1): updateJsonProfile instead of static profile/ zip for eisy-ui sync; requires IoX 6.0.6+, PG3x 3.4.5+, udi_interface 3.4.5+; install.sh renames profile/ to profile.static/ on EISY; profile/ XML remains source for data/base_profile.json; bump profile_version in server.json when JSON base changes
