September 22Sep 22 I upgraded to v6.1.1 which is supposed to have full implementation of the Admin Console in EISY-UI. After upgrading, I noticed that my LIFX lights don't respond to the program controls that I have set up. I tried to take a look at this today using EISY-UI and I cannot see where there is any way to access the network resources in EISY-UI. So then I started AC and tried to execute some LIFX resource that used to work and now they don't work and some throw errors. So is something broken or is this the new world and I have to rewrite/troubleshoot my network resources. Note that I have loaded the LIFX plugin through PG3 but I decided to stick with network resources because the plugin is limited in its capabilities.TIA for any help.Bob
September 22Sep 22 No changes, it is still supported. View/Edit exists in eisy-ui beta. However there is a UI bug that has issues with escaped chars, better to use admin console to edit until fixed.https://forum.universal-devices.com/topic/47042-eisy-ui-is-getting-there-heres-where-we-stand/
September 22Sep 22 When I upgraded from ISY994i (restore from backup) my network resources seemed not to work. They worked if I resaved them. I have quite a few. On a whim I tried exporting them and then restoring them, and after that they all worked. This was just one person one time and it's possible they would have worked after some other keystroke and the export/restore was irrelevant, but it's something that could be tried.
September 23Sep 23 I do recall that being the case for me as well. I think touching then saving brought them back to life, it's been a long while though...Tim
September 23Sep 23 Author Thank you both for your suggestions. I tried backing up and reloading the resources but that didn’t fix the issue. I’ll probably write a ticket and also try to use the LIFX plug in which means rewriting every function I use.
