Away Mode Program Questions
ricksaust
I would like to program an "Away Mode" program. What I have in mind is to have my letter "D" on my 6 button switch be the on switch for "Away Mode". I would like to push it when walking out the door on vacation. When this button was on if any light switch is turned on in the home that it would send an email alert plus flash the lights in the home to scare off any potential threat.
There are a couple problems that I am having.
1. It doesn't seem like the ISY picks up all of the events that happen. (For example I can turn on a light and leave it on for while and nothing will happen. Sometimes it catches that a light is on other times it doesn't)
2. It kind of seems like it starts multiply programs at the same time since it is flashing lights that are found in the IF statement.
3. When it runs through my Then it is not consistent. I never did get an email and it usually only blinks the living room light and randomly flashes the others.
There is probably a better way to do this just looking for some advice on what my problem might be or a better way to do it.
Current code listed below:
Status 'Utility Light.D' is not Off
And-(
Status 'Utility Light.1' is not Off
Or-(
Status 'Kitchen Lights' is not Off
Or Status 'Living Lights' is not Off
Or Status 'Master Bath Light' is not Off
Or Status 'Master Closet Light.1' is not Off
Or Status 'Master Lights' is not Off
Or Status 'Dining Lights' is not Off
Send Notification to 'Email'
Repeat 10 times
Set 'Living Lights' Fast On
Wait 1 second
Set 'Kitchen Lights' Fast On
Wait 1 second
Set 'Master Bath Lights' Fast On
Wait 1 second
Set 'Master Closet Light.1' Fast On
Wait 1 second
Set 'Master Lights' Fast On
Wait 1 second
Set 'Dining Lights' Fast On
Wait 1 second
Set 'Living Lights' Fast Off
Wait 1 second
Set 'Kitchen Lights' Fast Off
Wait 1 second
Set 'Master Bath Lights' Fast Off
Wait 1 second
Set 'Master Closet Light.1' Fast Off
Wait 1 second
Set 'Master Lights' Fast Off
Wait 1 second
Set 'Dining Lights' Fast Off
Wait 1 second
Thanks in advance for any suggestions,
Mike
Hi Mike,
What is happening is due to the fact that your program is turning on lights that are being checked in the conditions as being off.
It will probably be better to create a folder that has a condition of the KPL button and then create programs within that folder to watch for Control events rather that Status. Control will only activate when a switch is pressed while Status reacts whenever a light is turned on even if from another controller.
I also have to suggest that you create a scene containing all the lights and switch the scene On/Off rather than individual devices.
Rand
Sub-Routine(Rand),
Thanks for the advice.
When I create a scene with all of the lights I want controlled do I just have all of the lights as responders in that scene with no controllers?
Also if I have the ISY looking for Status do you have any idea how often it pull this information? I do like your idea to use a control instead but just curious how often it gathers this info since it didn't seem to work in my last program looking for that status.
Thanks again,
Mike
Yes, unless you want one of the included devices to control the scene. For use only within the program, no controller is necessary.
I am not sure that it "pull"s the information. Program conditions are evaluated each time one or more of the included device's status changes or a control is recieved. If nothing changes, a program will not execute.
Oberkc,
Thanks for you answers.
Alright here is what I have. Haven't tested yet but wanted to see if things looked like they would work.
Have an Away Mode scene with all the lights I would like to be part.
Then I have a folder with the following conditions:
Folder Conditions for 'Away Mode Status'
       Control 'Utility Light.C' is switched On
    Or Status  'Utility Light.C' is On
Code to check to see if a light switch was turned on while we were gone:
       Control 'Utility Light.1' is switched On
    Or Control 'Living Lights' is switched On
    Or Control 'Kitchen Lights' is switched On
    Or Control 'Dining Lights' is switched On
    Or Control 'Abby's Room' is switched On
    Or Control 'Austins Light' is switched On
    Or Control 'Master Bath Light' is switched On
    Or Control 'Master Light' is switched On
    Or Control 'Hall Main' is switched On
       Run Program 'Away ModeProgram' (If)
Code to flash lights and send notification of intruder:
       Repeat 10 times
          Set Scene 'Additional Scenes / Away Mode' On
          Wait  2 seconds
          Set Scene 'Additional Scenes / Away Mode' Off
          Wait  2 seconds
Guess I am still a little confused what the difference is between status and control so I put both for now. I would think that in this case I would want status to see if the away mode button was still pushed.
Mike
I think you are part of a large club. It comes, with time. There are MANY posts on this topic. I suggest checking them out.
The related question, the one that helps understand the difference between status and control, is "when are program and folder conditions evaluated?".
I think of the difference between control and status as being a control is generally true at a point in time...status can be true over a period of time. However, conditions are only evaluated when a control is recieved, or when there is a change of state in status. For example, the following condition:
control KPLA is switched on
and status KPLB is on
is evaluated any time a command related to KPLA is recieved, or the status of KPLB changes. If the status of KPLA changes to "on", the condition is evaluated. If the status of KPLB is already on, then the condition is true. I believe this is the only time this condition can be true.
If KPLA is switched off, the condition is evaluated. Obviously, the condition would be false. The harder one is when the status changes, forcing an evaluation. If the status changes to on, the condition will be evaluated and be so as false. Why? Because at that point in time of evluation there was no simultaneous reciept of KPLA control, which is also required for the condition to be true.
Anyhow, I hope I got it right and that I did not further confuse things. In your case, I think I would tend to use status of utility light C as the folder condition. In reality, I assume you could use either (status remains unchanged until the condition is reevaluated). The way you have it would work, I expect, but seems inelegant.
Is this the program called 'Away ModeProgram'? Is this program in the foler or outside of the folder?
One thing unclear to me at this point is whether your 'additional Scenes / Away Mode' includes the utility light.C. If so, then your folder will turn false as soon as the scene starts flashing and could halt your program if they are both in the folder.
Based upon the input of Subroutine, I assume that a scene and command is different than a control of an individual device, so I trust that turning off a scene that includes a device is not the same as sending a control for that device. If so, then this looks good to me. If, however, a device responding to a scene command reacts by transmitting a control command, then you may still have your infinite loop thing going on here.
No harm in trying it out. We can learn together.
I did have both programs in the away mode status folder. But I didn't have the utility.c in the scene. But you are right there is no need for both of them to be in there.
I tried the away mode last night and didn't get any results. Do I have to have an "IF" condition for the "THEN" to run?
I didn't have much time last night to troubleshoot much with it so I will take the one program out of the folder and try it again tonight.
Thanks for the link on the Control vs Status.
Mike
Yes, I would be tempted to take the second program out.
Not necessarily, but this question revealed a potential deficiency that we both missed in you first program. It should call up the "then" path, rather than the "if" path. Try:
       Run Program 'Away ModeProgram' (then)
See if this helps.
I have changed this to "Then" and will try it when i get back.
This does bring up another questions.
I see there are the following options:
Run (If)
Run Then
Run Else
Stop
Enable
Disable
Enable Run at Start up
Disable Run at Start up
Most of these make since but just curious the difference between:
Run (If)
Run Then
Run Else
Enable
I would think that the Run (If) would go with an if statement but you can't do a Run (If) program in the If statement just the Then or Else.
I looked on the wiki and was unable to find the difference on these. Not that they are not on there but I wasn't able to find them.
Mike
Hi Mike,
Run (If) evaluates the conditions and then proceeds to run the Then or Else actions.
Run (Then) and Run (Else) skips all conditions and runs the actions in the Then or Else section of the program.
Enable/Disable will allow the program to run based on Conditions or not run, no matter what the Conditions are.
Run At Startup will examine the Conditions whenever the ISY is restarted.
Rand
But, as indicated, Homelink learns the signal from your existing RF remote
I am assuming that your "away mode program" is the third code listed, which is the one which flashes the lights. Correct?
If correct, when your second code listing call to run program 'away ModeProgram" (If), there are no conditions to evaluate. I am assuming that this will never evaluate as true, and thus, never run the "then" commands.
If so, I still think you want to run (then).
      378.8k
