Setting "OFF" to 10% or Less
I want to be able to not completely turn a Christmas tree off. 1-3% would be perfect. 10% I'd settle for.
There are some logisticals reasons why I would want this to work.
Currently, this is my program:
       Control 'Master Bedroom KeyLinc C' is not switched On
    Or-(
      |     Status  'Master Bedroom Christmas Tree' < 30%
      |  Or Status  'Master Bedroom Christmas Tree' is not On
       Set 'Master Bedroom Christmas Tree' 10%
Is there a better way to accomplish this?
Also while we're at it, is there any way to control the OFF ramp rate using ISY? I do not want to set the local control for the slow ramp rate.
Joe
Create a Scene and put the tree in it. Then you can select any level and rate you like. Instead of controlling the tree turn on the scene.
Sub-Routine:
Thanks. I knew I was missing the simple approach. I'm a newbie here and just getting into it. The problem...as you well know...is the deeper you get, the more you realized what you don't know.
Joe
