Run Times Off by 2 Hours
My Last Run Time and Last Finish Time for programs that run on a schedule or event are showing as 2 hours later than the actual time that the program ran (showing as 2 hours into the future). The programs run on the correct scheduled time or event, but are shown in the summary view as 2 hours into the future. Manually running one of those programs with the 2 hours later time shown in the Summary View, result in the correct time being shown in the eisy Programs Summary view.
The System>Configuration current time and location are set and correct.
UDM shows the correct time for those programs that show as running 2 hours later in the eisy programs summary view. The eisy was power cycled yesterday.
How have I managed to hose this?
 eisy-ui 1.4.6
 IoX 6.1.2_10
 UDX 5.1.0
 PG3x 3.4.28
 mosquitto 2.0.18
 mDNSResponder 2881.100.56.0.1
 libwebsockets 4.3.3
14 minutes ago, bmercier said:
@wrj0, please change the timezone to something else, save, then change it back.
Bingo! That did the trick. Thanks @bmercier
Why is it that the simplest solutions often seem to escape me? 🙂
@bmercier I have just seen the same issue, but I am not sure I understand your recommendation. Are we changing the time zone in AC or EISY-ui? And where exactly is this done. I looked in EISY-ui and didn’t see anything.
I do graphs and trends in HA and data is not plotting correctly on the time axis and I am assuming that this time issue for when the data was last updated is part of the problem.
Edited by ISY4Me
Do this in eisy-ui, under System | Configuration.
The root cause is that the eisy-ui process was not in sync with the system & IoX timezone. With the latest eisy-ui release, changing the timezone changes it everywhere.
Just rebooting should also work. The eisy-ui process will be started with the system time, which should already be correct.
On my eisy, I had to perform the timezone change to another zone and change back. Rebooting or power cycling, did not correct the program logging time problem.
