November 7Nov 7 @Goose66 — I’m experiencing the same discovery issue.• Eisy-UI / IoX 6.1.2• ratgdo plugin Standard 4.0.8• Board: v32board_secplus2• Firmware: 32.0, ESPHome 2026.7.0The ratgdo works in Home Assistant, and its web page loads normally.Automatic discovery finds nothing. I added this custom parameter:gdodevice = 192.168.1.172;ratgdo32-46b680The plugin accepts it, but discovery fails with:404 Client Error: Not Found for url: http://192.168.1.172/text_sensor/firmware_versionIs there a plugin update or configuration workaround for this firmware? I want to retain the working Home Assistant setup.
Wednesday at 02:53 PM3 days There is a lot of discussion hereBottom line, you have to downgrade the firmware on the Ratgdo device for the plugin to work from github
