how to upload modbus.iox_plugin.json in eisy-ui
eisy-ai helped me generate a .json file for my soledge inverter but the documentation is no help explaining how to upload that file. do i add a custom configuration parameter? do I use the "files" tab?
I deleted the eisy-ui plugin and installed the pg3 version. There I can see the place to upload a .zip file that was missing in eisy-ui plugins.
unfortunately I get an error when I start the pg3 plugin.
2026-11-07 17:25:51.014 MainThread iox_p_logger       INFO     plugin:validate_json: fastjsonschema does not currently support file references ... ignoring validation request.
2026-11-07 17:25:51.014 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026068_30.cert key: 0021b9026068_30.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2026-11-07 17:25:51.014 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026068_30/modbus.py", line 40, in <module>
2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: plugin = Plugin(PLUGIN_FILE_NAME)
here's my modbus.iox_plugin.json. any ideas?
"device": {
"name": "SolarEdge SE7600H",
"host": "10.10.1.49",
"port": 1502,
"unit_id": 1,
"address_base": 0,
"poll_interval_s": 10,
"word_order": "big"
"inverter": [
{"name": "sunspec_did", "address": 40069, "count": 1, "type": "uint16"},
{"name": "ac_current_a", "address": 40071, "count": 1, "type": "uint16", "scale_register": 40075},
{"name": "ac_voltage_an_v", "address": 40079, "count": 1, "type": "uint16", "scale_register": 40082},
{"name": "ac_power_w", "address": 40083, "count": 1, "type": "int16", "scale_register": 40084},
{"name": "ac_frequency_hz", "address": 40085, "count": 1, "type": "uint16", "scale_register": 40086},
{"name": "ac_apparent_va", "address": 40087, "count": 1, "type": "int16", "scale_register": 40088},
{"name": "ac_energy_wh", "address": 40093, "count": 2, "type": "uint32", "scale_register": 40095},
{"name": "dc_current_a", "address": 40096, "count": 1, "type": "uint16", "scale_register": 40097},
{"name": "dc_voltage_v", "address": 40098, "count": 1, "type": "uint16", "scale_register": 40099},
{"name": "dc_power_w", "address": 40100, "count": 1, "type": "int16", "scale_register": 40101},
{"name": "heatsink_temp_c", "address": 40103, "count": 1, "type": "int16", "scale_register": 40106},
{"name": "status", "address": 40107, "count": 1, "type": "uint16"},
{"name": "status_vendor", "address": 40108, "count": 1, "type": "uint16"}
"meter1": [
{"name": "meter_did", "address": 40188, "count": 1, "type": "uint16"},
{"name": "meter_current_a", "address": 40190, "count": 1, "type": "int16", "scale_register": 40194},
{"name": "meter_voltage_an_v", "address": 40196, "count": 1, "type": "int16", "scale_register": 40203},
{"name": "meter_frequency_hz", "address": 40204, "count": 1, "type": "int16", "scale_register": 40205},
{"name": "meter_power_w", "address": 40206, "count": 1, "type": "int16", "scale_register": 40210},
{"name": "meter_power_a_w", "address": 40207, "count": 1, "type": "int16", "scale_register": 40210},
{"name": "meter_power_b_w", "address": 40208, "count": 1, "type": "int16", "scale_register": 40210},
{"name": "meter_apparent_va", "address": 40211, "count": 1, "type": "int16", "scale_register": 40215},
{"name": "meter_pf", "address": 40221, "count": 1, "type": "int16", "scale_register": 40225},
{"name": "grid_exported_wh", "address": 40226, "count": 2, "type": "uint32", "scale_register": 40242},
{"name": "grid_imported_wh", "address": 40234, "count": 2, "type": "uint32", "scale_register": 40242},
{"name": "meter_events", "address": 40293, "count": 2, "type": "uint32"}
