Tuesday at 05:01 PM2 days I successfully upgraded to eisy-ui. Now I have a few basic questions1-How to I edit my programs2-How do I access eisy-ui on my iphone
Tuesday at 05:15 PM2 days 1- If you go into "Programs" and select a program, you see your program on the right and it's in edit mode. For each section (If, Then, Else) there is a "Add" button to add lines. To change the order of lines, you click and drag them to where yoIf any program changes are made, you will see a "Save"u want them. To delete lines, you click on the line and then click on the garbage can icon in the edit window. If any program changes are made, you will see a "Save" button to save it. The garbage can icon at the top is to delete the program.2- it's browser based, so just fire up your phone browser and log into the same url as on your PC.
