Scene Controller Behavior in eisy-ui / UD Mobile
Hi! I just migrated from my ISY994 to the EISY (Insteon only). I previously used the Admin Console for local control and the Mobilinc app for remote control and am now moving over to UD Mobile and eisy-ui. One thing I have noticed is that when working in both the new mobile app and new ui, if I turn on a switch that is a controller for a scene, only that switch will turn on - none of the responders change state. In order to activate all nodes in the the scene you need to directly interact with the scene's node. (I should note that physically toggling the switch does effect the scene as expected.) With the old Admin Console/Mobilinc, if you would interact with a device's node, it would effect the other members of the scene. Is this expected?
