1 hour ago1 hr I am using a Honeywell T10+ thermostat which is configured to control an ERV ventilation device that is part of my HVAC system. I describe what features this adds to the thermostat below. It would be great, at a minimum, if the Ventilator State (seen on the T10+ at Equipment Status : Ventilator) could be added to the HomeKit Thermostat? Adding control of the ventilator could be a later goal?When the T10+ is configured to control an ERV, this adds the following status to the thermostat:Equipment Status: VentilatorWhen the T10+ is configured to control an ERV, this adds the following controls to the thermostat:Ventilation Mode: Options are: Auto On Off Auto: controls ventilation per the T10+ ventilation configuration settings On: forces ventilation on Off forces ventilation offVentilation Timer: Allows user to select an amount of time that ventilation will be forced onVentilation Options: Disable During Sleep: Options: On OffMy T10+ Configuration options that apply to ventilation (FYI for anyone interested)10000ventilation typeERV/HRVOptions: none, ERV/HRV, Passive(fan-only), Damper10005ventilation Model number otherOptions: other, certain specific Honeywell models10020what terminals wired to ventilator?tsat U terminalsOptions: None, tstat U, Eim U1, Eim U2, Eim U310050ventilation control methodpercent on timeOptions: ASHRAE, percent on time . see also 10120 10060ventilation fan controlequipment controls fanOptions: tstat controls fan, equipment controls fanTstat G output connected to ERV G inputERV Gf output connected to furnace G input10120ventilation percent on time30%Options: 10-100% Note: ERV mode is set to AUTo10130ventilation low temp lockoutoffOptions: off, 20-4010130ventilation high temp lockoutoffOptions: off, 80-11010130ventilation high dewpoint lockoutoffOptions: off, 65-8510170ventilator core clean remindoffOptions: off, 3,6,9,12 months10170ventilator filter clean remind12 monOptions: off, 3,6,9,12 months
