3 hours ago3 hr My 994i was on the latest with the 500 ZW board. Did the backups. Eisy is 6.1.2. My zw network is 9 devices, some battery, some plug in. I'm using the admin console, local.When migrating over, all my zw in the Main tab come over as disabled, all with placeholder. I've been working on this for a couple days now so I'm not going to bore anyone with everything I have tried (even if I could possibly remember it all).The only way I have successfully got some of my devices to work is the following. The first two I did, GE battery motion sensors worked this way. Right click on each individual node for the specific ZW0xx and Delete it (some nodes deleted several others also). Top menu Z-wave, Remove a ZW Device (it doesn't 'hear' the dev for 'Add a..." if I don't remove it first), wake up dev. Then Add a ZW device and wake it up. It then adds the thing, and shows 1011, so I Write Changes.The next one, zooz zse40, worked up to the last step above, but it locked up with WRITING on the Main tab, and it said System Busy (lower left corner). Nothing I did got it out of that state. I finally tried Restart the iox (Configuration tab) at which point the console went black. I couldn't even close the window. I finally unplugged power on the eisy and shut down with task manager the iox launcher thing. That lock up took about half an hour.After all that it came back up with 1011, so rt click on top node and Write Changes. There must be a more efficient way to do this migration, but I'm probably missing it. Some of my ZW nodes (garbage) have 13. I tried several of the wiki suggestions, such as Synchronize Update with Interview but it only flashed a very brief window (I think) and then did nothing. Maybe someone has some suggestions.
