13 hours ago13 hr I added a tool to the latest version of the plugin that lets you download the json file for an unsupported device. The json file typically includes everything I need to add it as a supported device to the plugin. You follow all the normal steps to add a device. If it is your first device, you add it to either the smartlife or tuya app. Then you create a tuya developer acct and link your app acct to it. Then the developer portal will give you an id and secret which you enter into the plugin via its html configuration interface. If you already have other devices configured to the plugin and have linked your new device to either the smartlife or tuya app you already associated to the plugin, just go directly the plugins html page.Then from the html config page, you click to retrieve devices from the cloud, then you click to scan local network, then click test connection, then you click to download the json file. Send me the json file along with the device make/model.
