14 hours ago14 hr I’ve noticed a difference in how input and preset controls are displayed between the eisy web UI and UD Mobile:In UD Mobile, the AVRServer node shows all available inputs and presets as dropdown menus, making it easy to pick an option.In the eisy web UI, these same controls do not show dropdown options—instead, no options appear even after hard refreshing the browser and clearing the cache.Other nodes or legacy controls do show dropdowns/arrows in the eisy UI, so I believe the plugin’s node profile and editors are set up correctly. The issue seems to be that the eisy web UI does not render subset/enum editors for node server plugins as UD Mobile does.Is this a known limitation or bug? Can this be improved in a future update so dropdowns and value lists from plugin profiles are available in the web UI too? Anyone else experiencing this?
