Trouble migrating to eisy plugin process
Is this working now under the new plugins vs pg3x?
I am not able to get it to work.. appears to go thru the full process of interacting with the eisy and collecting the data and then when it is writing it to the GV values, it shows two errors.
Bottom line, is that a NODE never shows up in the Eisy Node tree.
According to Eisy AI, the Eisy is denying it access, even though I have the Allow API Access turned to on and restarted.
DEBUG Log:
2026-11-23 20:13:52 debug: POLY: _sendMessage: sending
{"set":[{"address":"controller","driver":"GV4","value":"233","uom":56}]} to udi/pg3/ns/status/plugin_8
2026-11-23 20:13:52 debug: POLY: -> topic is udi/pg3/ns/clients/plugin_8, processing
2026-11-23 20:13:52 debug: NS: Message Received: {
set: [
address: 'controller',
driver: 'GV0',
error: 'Request failed with status code 404',
code: 404
[length]: 1
set: [
driver: 'GV4',
code: 404
[length]: 1
1994 lines
Edited by dbwarner5
Update: Eisy AI determined the following:
What I now think is happening The plugin's saved record lists the controller node, but the eisy itself doesn't have it. The likely cause is that the node was first added while the "Allow API access" slider was off. The plugin's side recorded it, and the eisy never got it. Since then the plugin has believed the node exists, so it never retries.
this was migrated over.
To test this, I did a new install in a completely new slot.
This time it worked. So the problem was in the migration from pg3x into the same slot.
