Need to convert to a new set up from ISY994i and PLM
I inherited a ISY994i and PLM (ethernet) set up in the home I purchased back in 2015. The system has over 30+ light switches and dimmers, two garage sensors /controls and plugs. Over the years the switches have died and the PLM or ISY944i has died. I am currently facing that with the PLM now. I think I am to a point where I need to update the hub or control. I am not super in-depth with this set up but have understood how to replace and update certain switches. What would this community recommend for a simple full house (light switches, dimmers, garage control) solution that will work with the Insteon switches still in place.
Thanks in Advance for any help or insight!!
rchairston
If you want to stay with UD your options are either the eisy-r2 or the eisy lite.
UD Store - Universal Devices
The 2413S PLM you're currently using is no longer offered by Insteon. The eisy uses the 2413U which is available from Insteon
PLM USB Modem Interface | Insteon
If you want something real simple check out the Insteon Hub which has a built-in PLM. It requires a annual subscription
Insteon Hub 2 Central Controller: App, Alexa and Google Home
