Wednesday at 04:44 AM1 day I updated the Tuya Smart life plugin so it will now work across vlan's. So you can put all your tuya smartlife stuff in an iot vlan and open just a single port between eisy and the iot vlan subnet. Process is as follows. 1) Click to retrieve cloud devices and keys. 2) Enter your tuya/smarlife device subnet (/24 to scan the entire range). Unclick "include local network. . " to save time if no devices are on the same subnet as eisy. Click "scan networks". It will pop up all the devices on that vlan and offer you to add it to eisy or if it is already configured but has a new ip address, it will offer you to just update the ip. The update IP feature works just as well for devices that have a new ip address for any reason, not just changing subnets. Don't forget to open a firewall hole between your eisy and TCP 6668 on the tuya/smartlife containing subnet.
