Aeris weather plugin (PG3x) working then not
I've been using NOAA weather but it stopped working a few days ago and I see the plugin is no longer available.
I switched to Aeris weather and got it working. Then I migrated the plugin to EISY plugins and it was still working. Woke up this morning and noticed the Aeris favorite was missing from UD Mobile. Logged into EISY via the web interface and the plug in was showing connected, but no nodes showing. Tried Eisy AI for diagnostics and determined something is wrong, but not sure what. (Mostly because I don't really know what I'm doing and just bumble along until it works or I give up.)
I stopped the EISY plug in version and reinstalled Aeris Weather as a PG3 plug in. The PG3 version connected and functions properly. EISY AI suggested I share the following summary so someone way smarter than me can figure out the issue. Below is from EISY AI:
Subject: Aeris Weather Plugin (eisy/PG3x) – Nodes Missing and "list index out of range" Errors
Message:
I encountered an issue with the Aeris Weather plugin on my eisy system. After updating to the eisy/PG3x version, all Aeris Weather nodes disappeared from both UD Mobile and the Nodes page, even though the plugin showed as “connected” in the plugin dashboard. Old programs and favorites using Aeris Weather failed because the nodes were missing.
The plugin logs repeatedly showed errors like:
ERROR query:query_conditions: Precipitation summary update failure: list index out of range
Location, credentials, and all configuration values were correct. Restarting the plugin did not restore the nodes.
However, after stopping the eisy/PG3x plugin and reinstalling the PG3 version instead, everything started working again—the nodes reappeared and the log errors disappeared.
It appears the eisy/PG3x-specific version may be mishandling empty or missing precipitation data in the Aeris API response, causing nodes not to be created.
Please let me know if you need more details or want me to test anything further!
Thank you,
EISY AI
NOTE: (me again) Migrated plug in didn't immediately fail as AI implies. It worked for a day then failed overnight. Also not mentioned, I tried changing to another location in case there was an issue specifically with my location. Also logged into Xweather to verify the system was up. All statuses green at Xweather and I have not exceeded my free API accesses yet. (Based on current usage, that will happen around day 15)
First, I don't know what happened to the NOAA plugin. I didn't remove it. I've opened a ticket with UDI for this.
For Aeris weather, let me summarize what I think you're saying to make sure I understand correctly.
  1. you install it using PG3x and it works fine. The nodes show up and are being populated.
  2. you migrate it to eisy plugins and the nodes are still there an populating for about a day.
  3. after about a day, the node disappear.
I'd need to see the plugin's debug logs for the time when the nodes disappear, but I don't think they'll really provide any answers since the plugin doesn't delete it's nodes.
What I can tell you is that typically when a plugin fails after migration, it's an eisy plugins issue. eisy plugins (per UDI) is fully compatible with PG3x plugins but it is new code so they are still finding and fixing issues with compatibility.
The error is probably more of a warning. It simply means that the incoming data from Aeris is missing precipitation data so you won't see that value updating in the node. It's not a fatal error and doesn't prevent the plugin from updating all the other values. It has nothing to do with the nodes disappearing.
