Sunrise and sunset times
These are the controller's own calculated values (the same ones its schedules use), read from the contoller's /rest/time once a day and converted to the controller's local time zone. Minutes are truncated (5:43:41 shows as 5:43). The plugin needs access to the controller for this (Allow API Access), which is enabled in its registration. After enabling API access, the plugin must be restarted, then up to a minute may be required for the values to appear.
