22 hours ago22 hr Still getting use to the new UI (eisy-ui). I am making sure I have performed Upgrade Packages when I log on..Everytime I make some type of update, I try to perform a backup. In the Admin Console, I was able to select the location for the backup file. For some reason, I cannot find where the backup file in located when I perform the backup in the eisy-ui. What am I missing or forgot to setup in eisy-ui?Thanks
22 hours ago22 hr if you are using a Mac Safari, under safari settings, general, you can choose "ask for each download" and then select.I would guess that other browsers do the same, or have a default folder for downloads.. look there.The point is that Eisy UI, doesn't control the download location.... your browser does. Edited 22 hours ago22 hr by dbwarner5
21 hours ago21 hr Author Thanks. Problem solved. Part of it was my fault. BTW - Windows just deposits the file into the Downloads folder.
