6 hours ago6 hr Following the recent eISY update all eISY Plug-ins had to be reinstalled. After reinstalling the YoLink local Plug-in, the node failed to display data so I decided to delete the Plug-in and start fresh. I installed the Plug-in, entered the configuration data and then restarted the Plug-in. The sensors did not appear as nodes. Only the yolink setup node appears. The log indicates an authentication error. Can you review the attached log and provide some insight.Thanks! YolinkLocal-log-2026-11-28T00-05-18.601Z.zip
3 hours ago3 hr Yolink is rejecting the credentials. i had similar issue before. i created new credentials at yolink and it solved it
