2843-222 Open/Close Sensor Shows up as 2842-422
I am posting here to notify UDI of a minor issue with the EISY-UI interface. I do not require any action as the sensors are working correctly. They are just not displayed incorrectly in the interface.
I recently installed two older Insteon 2843-222 Open/Close Sensors to use on two garage doors to detect when the doors are closed. I used the EISY-UI interface to add the sensors by selecting the 'Link a Sensor -- Open/Close' button on the Protocols > Insteon screen. Before adding them to EISY, I performed a Factory Reset on the two sensors.
As you can see, they are appearing in the EISY-UI interface as (2842-422) Insteon Motion Sensor v.34. They do have the two nodes (open and closed) and do function correctly.
In order to perhaps help provide more information, I added a third 2843-222 Open/Close Sensor to my system. I took screen shots throughout the add process and have pointed out the discrepancies I noticed. Below is a picture of the device's label showing its model. It is labeled a 2843-2. The label on the inside of the device shows a date code of 4712 (Nov 18, 2012) and hardware revision 1.6. I performed a factory reset on this device before adding.
Within the EISY-UI, I went to Protocols > Insteon and then clicked on the 'Link a Sensor -- Open/Close' button. Notice the Name of 'Test'. I provided the Insteon address. The device type was preselected for 2843-222. I put the device in linking mode, then clicked OK.
Below is a snapshot of the finished screen. Notice the two node names highlighted in yellow. These are NOT the names the nodes were actually given. (Note, you are able to fully rename the nodes.)
Below is a screen shot of the two actual names the nodes were given in EISY-UI. Only the Node 2 name actually contained the 'Test' prefix I provided when adding. Also notice the incorrect device type of 2842-422.
Out of curiosity, I opened the old Admin Console, just to see what it showed for this device. The node names were the same as in EISY-UI. But notice that the device type in the Admin Console shows the device as a (2421) TriggerLinc v3.4 (the predecessor to the 2843).
Another concern I noticed is that the device appears to have the wrong configuration screen in EISY-UI. On the Nodes screen, I right-clicked node-1 of the 2843 device and selected 'Configuration'.
I then clicked the Options button and received the pop-up screen below. Perhaps this is the configuration screen of a true 2842-422 Motion Sensor. Nothing works on this pop-up screen. Notice the Internal server error message I highlighted in yellow.
I hope this information is helpful.
Sincerely,
-Emile
Edited by EVictory
