15 hours ago15 hr The current direction from Universal Devices is that matter-over-thread devices will be supported by adding a thread border router. (The eisy descriptions in the Universal Devices store state this.) I am starting this discussion in an attempt to understand better what using a thread border router might involve:What border routers are recommended? What experience does the community have with using a thread border router and matter-over-thread devices?How would a matter-over-thread device be "installed" as an IoX device? What limitations might be present with respect to the IoX programming language and a matter-over-thread device?NOTE: To be clear, the Zmatter dongle does not and will not support matter-over-thread devices. For a period of time in the past, that capability was a possibility in the Universal Devices roadmap, but that is no longer the case.
15 hours ago15 hr A Thread border router is an "invisible" device. No configuration, settings, none. You just put it there, plug it in, and it works. I have a Amazon Echo 4th generation that does this. I also have a Eero 6 router setup that has this built-in. I guess UDI saw no value in reinventing the wheel.See the list of devices that have this functionality here:Matter AlphaThread Border Routers: The complete list of what you can...Although Thread doesn't need a "hub" in the traditional sense, you will still need another piece of hardware—a Border Router—to take advantage of its benefits. Here are all the Thread Border Routers o
15 hours ago15 hr Author @Guy Lavoie What matter-over-thread devices are you using? How do you install a matter-over-thread device in IoX?
15 hours ago15 hr 4 minutes ago, wmcneil said:@Guy Lavoie What matter-over-thread devices are you using? How do you install a matter-over-thread device in IoX?Well I mostly experimented with Matter last spring, as a learning experience, when UDI was adding Matter support in IoX. I'd have to redo my tests because they apparently have improved the implementation. At the time it was difficult to directly configure a new Matter device directly in IoX. It was easier to first configure the device in Google Home or some other platform, and then use a share code to add it to IoX. Another thing is that I was mostly experimenting with a test Polisy, and it is now considered not to officially support Matter on the Polisy. It's ipv6 is an issue. But I still do have a light bulb (Thread too) that's configured on my eisy. I'll redo my tests eventually. These days I'm just more involved with eisy-ui, eisy-ai, etc.Installing a Matter over Thread device isn't any different from a Matter over wifi one. It's totally transparant, as long as you have a border router installed.
15 hours ago15 hr For what it is worth, I have a Google hub, second generation and an Alexa hub, both can act as thread border routers. I have recently added an eero Network to my house which also includes a border router capability. So far, my perception is that the eero works in conjunction with Alexa or Google or Apple or something like that in order to incorporate thread devices into the network. It is my understanding that all my thread border routers work with each other.In order to add a thread device to eisy, one must first add it to something that actually has a border router in it. Such as, again, Alexa, Google, whatever. Whatever. From Google, for example, one adds a new device and either scans the bar code printed on the actual device or by typing him the numeric code by hand. Either seem to work fine for me once added to Google or Alexa, share it from Alexa or Google or something else to eisy. This is done by going to the device in Alexa or Google and sharing it, which would generate another barcode or numeric code. Then, from eisy, go to your protocols, choose matter, and add new matter device from there. It will ask for the code. Type it in. If you are lucky, it will find the device and add it to your nodes. If you are less than lucky, don't hesitate to try it again. Sometimes it takes more than one try. I have had mixed success so far with matter but I remain hopeful that it will continue to improve. I think both Alexa and Google have updated their matter versions on my devices and I also hope that the addition of the ero border routers will improve my long-term consistency. So far, the only thread devices I have are a couple of light bulbs with which I am experimenting. I have a good number of govi devices that have matter over Wi-Fi. Only one remains connected by a matter. At this point. I am waiting for a quiet time to pick it back up and continue trying.
14 hours ago14 hr 2 minutes ago, oberkc said:In order to add a thread device to eisy, one must first add it to something that actually has a border router in it. Hmm, I don't think so. I only had a Google Home mini and my eisy, neither of which has a border router. Then I added the 4th gen Echo just to have a border router in vicinity, but still started by adding the Thread bulb (the Nanoleaf) to Google Home and then sharing to eisy. I'd be happy to be proven wrong... I was just experimenting. Interesting that the other Matter experimenter has chimed in! I think we're becoming due for another round of testing.
14 hours ago14 hr Author I don't yet have any matter devices, but I am 100% certain that a matter-over-thread device must connect to the thread mesh phy (802.15.4) in order to communicate. A matter-over-ethernet or matter-over-wifi device uses the wired ethernet or wifi phy layer, respectively, to communicate. Unlike a matter-over-ethernet or matter-over-wifi device, a matter-over-thread device requires a border router to bridge from the thread mesh to the ethernet (wired or wifi) network that the eisy is connected to.I have three eero mesh router devices that each have thread border router capability, so I will be able to test things out once I obtain my first matter-over-thread device. From what I read, looks like I will use the Alexa app to pair the matter-over-thread device to my EERO border router(s), using the matter-over-thread device's QR code. Then I would add the matter-over-thread device to the IoX, using the same QR code I guess?
13 hours ago13 hr 22 minutes ago, wmcneil said:I have three eero mesh router devices that each have thread border router capability, so I will be able to test things out once I obtain my first matter-over-thread device. From what I read, looks like I will use the Alexa app to pair the matter-over-thread device to my EERO border router(s), using the matter-over-thread device's QR code. Then I would add the matter-over-thread device to the IoX, using the same QR code I guess?That would be a good way to start, yes. Though you wouldn't be adding the device to a second controller using the same QR code. That won't work. The QR code is only for adding the device from a factory reset condition. To add the device to IoX (after having added it to Alexa), you need to use a share code (PIN or QR code) generated by the Alexa app.Though in the name of science...I'd be curious if you first tried adding the Thread device directly to the eisy first, just to see if it works as-is. One thing is that IoX doesn't yet seem to have the capability of generating share codes, so adding it to IoX first would prevent you from adding it to anything else by sharing.
13 hours ago13 hr Author 11 minutes ago, Guy Lavoie said:That would be a good way to start, yes. Though you wouldn't be adding the device to a second controller using the same QR code. That won't work. The QR code is only for adding the device from a factory reset condition. To add the device to IoX (after having added it to Alexa), you need to use a share code (PIN or QR code) generated by the Alexa app.Though in the name of science...I'd be curious if you first tried adding the Thread device directly to the eisy first, just to see if it works as-is. One thing is that IoX doesn't yet seem to have the capability of generating share codes, so adding it to IoX first would prevent you from adding it to anything else by sharing.Thanks for the clarification of (subsequent) share code for pairing a matter device that has previously paired (with another controller/ecosystem, whatever the correct word is) vs. initial code for the first pair. We definitely need Universal Devices to weigh in here with their intentions regarding matter share code generation. You ask a very good question: Is it possible to have the very first pair for a matter-over-thread (MoT) device be with eisy? Seems like this would require that the matter protocol allows a new MoT device to automatically connect to the border router?, and if so, obviously the border router support this capability?
12 hours ago12 hr 32 minutes ago, wmcneil said:Thanks for the clarification of (subsequent) share code for pairing a matter device that has previously paired (with another controller/ecosystem, whatever the correct word is) vs. initial code for the first pair. We definitely need Universal Devices to weigh in here with their intentions regarding matter share code generation.You ask a very good question: Is it possible to have the very first pair for a matter-over-thread (MoT) device be with eisy? Seems like this would require that the matter protocol allows a new MoT device to automatically connect to the border router?, and if so, obviously the border router support this capability?I consider the UDI implementation to be still somewhat incomplete, given the lack of being able to produce share codes. Implementation of Matter is long and difficult, give them time. It wouild probably be farther along if it weren't for eisy-ui and eisy-ai. But most of us will have another platform that supports Matter, such as Alexa or Google home, so this isn't a showstopper.Like I said previously, the border router is totally transparent. Yes, IoX will automatically access the device through the router if it's a Thread device. I suspect that Thread devices have a pre-established ipv6 address space (MAC addresses) and that a border router seeing a packet coming or going with one of these addresses will automatically know to route the packet across. It must be something like that.
10 hours ago10 hr 3 hours ago, Guy Lavoie said:I only had a Google Home mini and my eisy, neither of which has a border routerYes, but you had the Echo and Eero system, it sounds like, which had a border router. The point that I was trying to make was that the Eero, alone, appears to me to be unable to add a thread device, even though it has the thread border router. (There appears to be no option in the Eero app to include a thread device into the network). It appears to me that the Eero system requires another device, such as an echo or nest hub, or apple home, in order to initiate the thread device inclusion process. I suspect you are correct, however, that the google or echo devices do not actually need to include thread, themselves, so long as the Eero or another border router exists in your network.
10 hours ago10 hr Author 1 hour ago, Guy Lavoie said:I consider the UDI implementation to be still somewhat incomplete, given the lack of being able to produce share codes. Implementation of Matter is long and difficult, give them time. It wouild probably be farther along if it weren't for eisy-ui and eisy-ai. But most of us will have another platform that supports Matter, such as Alexa or Google home, so this isn't a showstopper.I have no problem with UD needing time to implement matter, or anything else. What is frustrating is when communication about roadmap/direction is less than it could be. I have owned two zmatter boards since they first came out in 2022. I still own two polisy boxes, but have replaced them with two eisy boxes. I just want to know which way the wind blows.
10 hours ago10 hr 3 hours ago, wmcneil said:From what I read, looks like I will use the Alexa app to pair the matter-over-thread device to my EERO border router(s), using the matter-over-thread device's QR code.Yes, that is how it worked for me.3 hours ago, wmcneil said:Then I would add the matter-over-thread device to the IoX, using the same QR code I guess?No. Different QR code. Once you pair it with Alexa app, you must share it FROM Alexa to IoX. That process would generate a different QR code.3 hours ago, Guy Lavoie said:I'd be curious if you first tried adding the Thread device directly to the eisy first,I have tried. No luck so far. I may try again now that I have the Eero system added to my setup.
