fgallina Posted October 7, 2010 Share Posted October 7, 2010 Hi, I've seen many topics with similar subjects, but none seem to address my specific problem. I bought a venstar thermostat with a v2 adapter, and I'm able to control it from the isy, but unless I click "query," the temperature reflected in the isy is never correct (nor is the setpoint, unless I don't change it on the thermostat itself). I have an access point just a few feet away from the thermostat, and I'm not having other communication issues in the house, so I'm not sure what's going on. As long as I manually query, the isy is accurate, but I don't want to have to do that. Anyone have any suggestions? I'm currently running firmware 2.7.15. Thanks! Frank Link to comment Share on other sites More sharing options...
Mark Sanctuary Posted October 18, 2010 Share Posted October 18, 2010 What your describing sounds like its acting like a v1 version of the thermostat adapter. Two things I can think of you might try... [*:1p0e4577]updating the ISY firmware[*:1p0e4577]removing/relinking the thermostat adapter to the ISY Wiki: Linking a Thermostat Thanks, Link to comment Share on other sites More sharing options...
LeeG Posted October 18, 2010 Share Posted October 18, 2010 The tstat adaptor has specific linking requirements as far as the mode the tstat must be in. The Wiki documents those requirements. Link to comment Share on other sites More sharing options...
