I can't get more than one button programed to IRLinc RX
Illusion
IRLinc V.92 added under 2.7.15 using 'New INSTEON Device' since I had no clue about 'Link Management "Add Button"' option. Gets added as 'Button A" I guess. I can press the up or down button on 'Button A" on the CC remote and it show up in the event viewer.
I upgraded to 2.8.2. Now I am trying to work with that IRlinc Receiver. I try to add another button using 'Add Button to IRLinc Receiver'. I follow instructions exactly. This is what I get in the level 3 event viewer:
Sat 10/09/2010 01:24:42 PM : [LNK-BGN     ] 02 64 00 00 06
Sat 10/09/2010 01:24:43 PM : [LNK-STAT    ] 02 53 S(00) gid=04 12.F5.69 0000 00
Sat 10/09/2010 01:24:43 PM : Linked: Linked 12.F5.69.04 type=03.06.FFFFFF92
Sat 10/09/2010 01:24:43 PM : [12.F5.69.4] Start : Adding device to ISY
Sat 10/09/2010 01:24:43 PM : [12.F5.69.4] Finish : Adding device to ISY was Successful
Sat 10/09/2010 01:24:43 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 01:24:43 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Sat 10/09/2010 01:24:43 PM : [12 F5 69 4  ] Link    3 : 0FE0 [E2040CA633FF1F04] Saving  [E2040CA633FF1F04]
Sat 10/09/2010 01:24:44 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 01:24:44 PM : [12 F5 69 1  ] Using engine version i1 for 'IRLinc RX.A'
Sat 10/09/2010 01:24:44 PM : [12 F5 69 1  ] Link    3 : 0FE0 [E2040CA633FF1F04] Writing [E2040CA633FF1F04]
Sat 10/09/2010 01:24:44 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:45 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:45 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E0 06          PEEK   (E0)
Sat 10/09/2010 01:24:45 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B E2    PEEK   (E2)
Sat 10/09/2010 01:24:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:46 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E1 06          PEEK   (E1)
Sat 10/09/2010 01:24:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 04    PEEK   (04)
Sat 10/09/2010 01:24:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:47 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E2 06          PEEK   (E2)
Sat 10/09/2010 01:24:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 01:24:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 64 6D 4C           (4C)
Sat 10/09/2010 01:24:47 PM : [standard-Cleanup Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=0, Hops Left=1
Sat 10/09/2010 01:24:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:48 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E3 06          PEEK   (E3)
Sat 10/09/2010 01:24:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 01:24:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:49 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E4 06          PEEK   (E4)
Sat 10/09/2010 01:24:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 01:24:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 01:24:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 01:24:50 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E5 06          PEEK   (E5)
Sat 10/09/2010 01:24:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 03    PEEK   (03)
Sat 10/09/2010 01:24:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 FF 06          POKE   (FF)
Sat 10/09/2010 01:24:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 FF    POKE   (FF)
Sat 10/09/2010 01:24:51 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E6 06          PEEK   (E6)
Sat 10/09/2010 01:24:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 05    PEEK   (05)
Sat 10/09/2010 01:24:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 1F 06          POKE   (1F)
Sat 10/09/2010 01:24:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 1F    POKE   (1F)
Sat 10/09/2010 01:24:52 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E7 06          PEEK   (E7)
Sat 10/09/2010 01:24:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 63    PEEK   (63)
Sat 10/09/2010 01:24:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 04 06          POKE   (04)
Sat 10/09/2010 01:24:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 04    POKE   (04)
Sat 10/09/2010 01:24:53 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 01:24:53 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 12 F5 69 03 06 92 15
Sat 10/09/2010 01:24:53 PM : [PLM         ] Group   4 : Writing Responder Link matching [12 F5 69 1  ] Link    3 : 0FE0 [E2040CA633FF1F04]
Sat 10/09/2010 01:24:55 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 01:24:55 PM : ---- All Linked Devices are now initialized ----
Button was added using 'Automatic' Link Management method. The button shows up in the device tree and I can even add it to scenes and it will control the devices in that scene. Problem is the ISY does not see it. No activity shows up in the event viewer and the status of devices in the scene of course are not updated, nor the status of the scene switch.
So I try adding a button using the 'Device Reported' Link Management method. I get a different procedure:
Sat 10/09/2010 02:09:17 PM : [LNK-BGN     ] 02 64 00 00 06
Sat 10/09/2010 02:09:18 PM : [LNK-STAT    ] 02 53 S(00) gid=05 12.F5.69 0000 00
Sat 10/09/2010 02:09:18 PM : Linked: Linked 12.F5.69.05 type=03.06.FFFFFF92
Sat 10/09/2010 02:09:18 PM : [12.F5.69.5] Start : Adding device to ISY
Sat 10/09/2010 02:09:18 PM : [12.F5.69.5] Finish : Adding device to ISY was Successful
Sat 10/09/2010 02:09:19 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:09:19 PM : [12 F5 69 1  ] Querying engine version
Sat 10/09/2010 02:09:19 PM : [LNK-END     ] 02 65 06
Sat 10/09/2010 02:09:19 PM : [standard Msg. Handler] Unexpected Ack imCmd=65 cmd1= 0x69
Sat 10/09/2010 02:09:19 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 0D 00 06                 (00)
Sat 10/09/2010 02:09:19 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 0D 01           (01)
Sat 10/09/2010 02:09:19 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:09:19 PM : [12 F5 69 1  ] Retrieved engine version is i2
Sat 10/09/2010 02:09:20 PM : [12 F5 69 5  ] Link    4 : 0FD8 [E2050CA633FF1F05] Saving  [E2050CA633FF1F05]
Sat 10/09/2010 02:09:21 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:09:21 PM : [12 F5 69 1  ] Using engine version i2 for 'IRLinc RX.A'
Sat 10/09/2010 02:09:21 PM : [12 F5 69 1  ] Link    4 : 0FD8 [E2050CA633FF1F05] Writing [E2050CA633FF1F05]
Sat 10/09/2010 02:09:22 PM : [iNST-ACK    ] 02 62 12.F5.69 1F 2F 00 00 00 0F DF 01 00 00 00 00 00 00 00 00 00 06        (00)
Sat 10/09/2010 02:09:22 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2F 00           (00)
Sat 10/09/2010 02:09:22 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:09:22 PM : [iNST-ERX    ] 02 51 12 F5 69 0C A6 33 11 2F 00 01 01 0F DF 01 E2 05 0C A6 33 03 05 63 00
Sat 10/09/2010 02:09:22 PM : [Extended-Direct][12.F5.69-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sat 10/09/2010 02:09:22 PM : [iNST-ACK    ] 02 62 12.F5.69 1F 2F 00 00 02 0F DF 08 E2 05 0C A6 33 FF 1F 05 00 06        (00)
Sat 10/09/2010 02:09:23 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2F 00           (00)
Sat 10/09/2010 02:09:23 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:09:24 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 12 F5 69 03 06 92 15
Sat 10/09/2010 02:09:24 PM : [PLM         ] Group   5 : Writing Responder Link matching [12 F5 69 1  ] Link    4 : 0FD8 [E2050CA633FF1F05]
Sat 10/09/2010 02:09:25 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:09:25 PM : ---- All Linked Devices are now initialized ----
But with the same end result. No status update, no sign of any activity in the event viewer in response to button presses.
Now bear in mind, the 'Button A' on the remote works fine. This is the button that the ISY added via the 'New INSTEON Device' method.
So I go back to 'Automatic' and try to link another button:
Sat 10/09/2010 02:12:44 PM : [LNK-BGN     ] 02 64 00 00 06
Sat 10/09/2010 02:12:45 PM : [LNK-STAT    ] 02 53 S(00) gid=06 12.F5.69 0000 00
Sat 10/09/2010 02:12:45 PM : Linked: Linked 12.F5.69.06 type=03.06.FFFFFF92
Sat 10/09/2010 02:12:45 PM : [12.F5.69.6] Start : Adding device to ISY
Sat 10/09/2010 02:12:45 PM : [12.F5.69.6] Finish : Adding device to ISY was Successful
Sat 10/09/2010 02:12:45 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:12:45 PM : [12 F5 69 6  ] Link    5 : 0FD0 [E2060CA633FF1F06] Saving  [E2060CA633FF1F06]
Sat 10/09/2010 02:12:45 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Sat 10/09/2010 02:12:46 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:12:46 PM : [12 F5 69 1  ] Using engine version i1 for 'IRLinc RX.A'
Sat 10/09/2010 02:12:46 PM : [12 F5 69 1  ] Link    5 : 0FD0 [E2060CA633FF1F06] Writing [E2060CA633FF1F06]
Sat 10/09/2010 02:12:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:47 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D0 06          PEEK   (D0)
Sat 10/09/2010 02:12:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B E2    PEEK   (E2)
Sat 10/09/2010 02:12:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:48 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D1 06          PEEK   (D1)
Sat 10/09/2010 02:12:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 06    PEEK   (06)
Sat 10/09/2010 02:12:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:49 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D2 06          PEEK   (D2)
Sat 10/09/2010 02:12:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:12:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:50 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D3 06          PEEK   (D3)
Sat 10/09/2010 02:12:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:12:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:51 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D4 06          PEEK   (D4)
Sat 10/09/2010 02:12:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:12:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:12:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:12:52 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D5 06          PEEK   (D5)
Sat 10/09/2010 02:12:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 03    PEEK   (03)
Sat 10/09/2010 02:12:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 FF 06          POKE   (FF)
Sat 10/09/2010 02:12:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 FF    POKE   (FF)
Sat 10/09/2010 02:12:53 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D6 06          PEEK   (D6)
Sat 10/09/2010 02:12:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 05    PEEK   (05)
Sat 10/09/2010 02:12:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 1F 06          POKE   (1F)
Sat 10/09/2010 02:12:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 1F    POKE   (1F)
Sat 10/09/2010 02:12:54 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D7 06          PEEK   (D7)
Sat 10/09/2010 02:12:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 63    PEEK   (63)
Sat 10/09/2010 02:12:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 06 06          POKE   (06)
Sat 10/09/2010 02:12:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 06    POKE   (06)
Sat 10/09/2010 02:12:55 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:12:55 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 12 F5 69 03 06 92 15
Sat 10/09/2010 02:12:55 PM : [PLM         ] Group   6 : Writing Responder Link matching [12 F5 69 1  ] Link    5 : 0FD0 [E2060CA633FF1F06]
Sat 10/09/2010 02:12:57 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:12:57 PM : ---- All Linked Devices are now initialized ----
Same failures. I 'Remove Device' for all nodes of said IRLinc:
Sat 10/09/2010 02:18:34 PM : [12 F5 69 C  ] Link   11 : 0FA0 [620C0CA633FF1F0C] Saving  [62..............]
Sat 10/09/2010 02:18:35 PM : [MNG-LNK-RSP ] 02 6F 80 E2 00 12 F5 69 03 06 92 15
Sat 10/09/2010 02:18:36 PM : [12 F5 69 1  ] Using engine version i1 for 'IRLinc RX.A'
Sat 10/09/2010 02:18:36 PM : [12 F5 69 1  ] Link   11 : 0FA0 [620C0CA633FF1F0C] Writing [62..............]
Sat 10/09/2010 02:18:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:18:36 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:18:36 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:18:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A0 06          PEEK   (A0)
Sat 10/09/2010 02:18:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B E2    PEEK   (E2)
Sat 10/09/2010 02:18:37 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:18:37 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 62 06          POKE   (62)
Sat 10/09/2010 02:18:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 62    POKE   (62)
Sat 10/09/2010 02:18:37 PM : [MNG-LNK-RSP ] 02 6F 80 A2 0C 12 F5 69 03 06 92 15
Sat 10/09/2010 02:18:37 PM : [PLM         ] Group  12 : Deleting Responder Link matching [12 F5 69 1  ] Link   11 : 0FA0 [620C0CA633FF1F0C]
I add the IRLinc back to the ISY via 'New INSTEON Device' choosing to keep all links and all devices reported. I am hoping since I programed all the buttons on the CC remote into the IRLinc it will pull at that stuff in and work like 'Button A' has been working for me:
Sat 10/09/2010 02:21:30 PM : [iNST-SRX    ] 02 50 14.07.EE 0C.A6.33 03 6E 4F           (4F)
Sat 10/09/2010 02:21:30 PM : [standard-Direct][14.07.EE-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sat 10/09/2010 02:21:30 PM : [   14 7 EE 1]       ST 158
Sat 10/09/2010 02:22:24 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:22:24 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:22:24 PM : ---- Add remaining devices ----
Sat 10/09/2010 02:22:24 PM : [  12 F5 69 1] Reading all links
Sat 10/09/2010 02:22:24 PM : [12 F5 69 1  ] Querying engine version
Sat 10/09/2010 02:22:24 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 0D 00 06                 (00)
Sat 10/09/2010 02:22:24 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 0D 01           (01)
Sat 10/09/2010 02:22:24 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:24 PM : [12 F5 69 1  ] Retrieved engine version is i2
Sat 10/09/2010 02:22:24 PM : [12 F5 69 1  ] Calibrating engine version ensuring support for i2
Sat 10/09/2010 02:22:24 PM : [iNST-ACK    ] 02 62 12.F5.69 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 00 06        (00)
Sat 10/09/2010 02:22:25 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2F 00           (00)
Sat 10/09/2010 02:22:25 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:25 PM : [iNST-ERX    ] 02 51 12 F5 69 0C A6 33 11 2F 00 01 01 0F FF 01 62 01 0C A6 33 FF 1F 01 00
Sat 10/09/2010 02:22:25 PM : [Extended-Direct][12.F5.69-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sat 10/09/2010 02:22:25 PM : [12 F5 69 1  ] Using engine version i1
Sat 10/09/2010 02:22:25 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:26 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:26 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:26 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F8 06          PEEK   (F8)
Sat 10/09/2010 02:22:26 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:26 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:27 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:27 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:27 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FA 06          PEEK   (FA)
Sat 10/09/2010 02:22:27 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:27 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:28 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:28 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:28 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FB 06          PEEK   (FB)
Sat 10/09/2010 02:22:28 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:28 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:29 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:29 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:29 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FC 06          PEEK   (FC)
Sat 10/09/2010 02:22:29 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:29 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:30 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:30 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:30 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F0 06          PEEK   (F0)
Sat 10/09/2010 02:22:30 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:30 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:31 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:31 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:31 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F2 06          PEEK   (F2)
Sat 10/09/2010 02:22:31 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:31 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:32 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:32 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:32 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F3 06          PEEK   (F3)
Sat 10/09/2010 02:22:32 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:32 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:33 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:33 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:33 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F4 06          PEEK   (F4)
Sat 10/09/2010 02:22:33 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:33 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:34 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:34 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:34 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E8 06          PEEK   (E8)
Sat 10/09/2010 02:22:34 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:34 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:35 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:35 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:35 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EA 06          PEEK   (EA)
Sat 10/09/2010 02:22:35 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:35 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:36 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:36 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EB 06          PEEK   (EB)
Sat 10/09/2010 02:22:36 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:37 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:37 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EC 06          PEEK   (EC)
Sat 10/09/2010 02:22:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:37 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:38 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:38 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:38 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E0 06          PEEK   (E0)
Sat 10/09/2010 02:22:38 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:38 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:39 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:39 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:39 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E2 06          PEEK   (E2)
Sat 10/09/2010 02:22:39 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:39 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:40 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:40 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:40 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E3 06          PEEK   (E3)
Sat 10/09/2010 02:22:40 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:40 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:41 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:41 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:41 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E4 06          PEEK   (E4)
Sat 10/09/2010 02:22:41 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:41 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:42 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:42 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:42 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D8 06          PEEK   (D8)
Sat 10/09/2010 02:22:42 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:42 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:43 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:43 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:43 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B DA 06          PEEK   (DA)
Sat 10/09/2010 02:22:43 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:43 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:44 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:44 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:44 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B DB 06          PEEK   (DB)
Sat 10/09/2010 02:22:44 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:44 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:45 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:45 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B DC 06          PEEK   (DC)
Sat 10/09/2010 02:22:45 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:46 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D0 06          PEEK   (D0)
Sat 10/09/2010 02:22:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:47 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D2 06          PEEK   (D2)
Sat 10/09/2010 02:22:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:48 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D3 06          PEEK   (D3)
Sat 10/09/2010 02:22:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:49 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D4 06          PEEK   (D4)
Sat 10/09/2010 02:22:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:50 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C8 06          PEEK   (C8)
Sat 10/09/2010 02:22:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:51 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B CA 06          PEEK   (CA)
Sat 10/09/2010 02:22:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:52 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B CB 06          PEEK   (CB)
Sat 10/09/2010 02:22:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:53 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B CC 06          PEEK   (CC)
Sat 10/09/2010 02:22:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:54 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C0 06          PEEK   (C0)
Sat 10/09/2010 02:22:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:55 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C2 06          PEEK   (C2)
Sat 10/09/2010 02:22:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:22:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:56 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:56 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C3 06          PEEK   (C3)
Sat 10/09/2010 02:22:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:22:56 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:57 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C4 06          PEEK   (C4)
Sat 10/09/2010 02:22:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:22:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:58 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:58 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B8 06          PEEK   (B8)
Sat 10/09/2010 02:22:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:22:58 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:22:59 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:22:59 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:22:59 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B BA 06          PEEK   (BA)
Sat 10/09/2010 02:23:00 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:23:00 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:00 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B BB 06          PEEK   (BB)
Sat 10/09/2010 02:23:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:23:01 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B BC 06          PEEK   (BC)
Sat 10/09/2010 02:23:02 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:23:02 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:02 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:02 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:02 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B0 06          PEEK   (B0)
Sat 10/09/2010 02:23:03 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:23:03 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:03 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:03 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:03 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B2 06          PEEK   (B2)
Sat 10/09/2010 02:23:04 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:23:04 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:04 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:04 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:04 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B3 06          PEEK   (B3)
Sat 10/09/2010 02:23:05 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:23:05 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:05 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:05 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:05 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B4 06          PEEK   (B4)
Sat 10/09/2010 02:23:06 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:23:06 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:06 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:06 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:06 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A8 06          PEEK   (A8)
Sat 10/09/2010 02:23:07 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:23:07 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:07 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:07 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:07 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B AA 06          PEEK   (AA)
Sat 10/09/2010 02:23:08 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:23:08 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:08 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:08 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:08 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B AB 06          PEEK   (AB)
Sat 10/09/2010 02:23:09 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:23:09 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:09 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:09 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:09 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B AC 06          PEEK   (AC)
Sat 10/09/2010 02:23:10 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:23:10 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:10 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:10 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:10 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A0 06          PEEK   (A0)
Sat 10/09/2010 02:23:11 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:23:11 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:11 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:11 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:11 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A2 06          PEEK   (A2)
Sat 10/09/2010 02:23:12 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:23:12 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:12 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:12 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:12 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A3 06          PEEK   (A3)
Sat 10/09/2010 02:23:13 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:23:13 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:13 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:13 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:13 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A4 06          PEEK   (A4)
Sat 10/09/2010 02:23:14 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:23:14 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:14 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:14 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:14 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B 98 06          PEEK   (98)
Sat 10/09/2010 02:23:15 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 00    PEEK   (00)
Sat 10/09/2010 02:23:15 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:15 PM : [  12 F5 69 1] Adding device to ISY
Sat 10/09/2010 02:23:15 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 10 00 06          ID-REQ (00)
Sat 10/09/2010 02:23:15 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 10 00    ID-REQ (00)
Sat 10/09/2010 02:23:16 PM : [iNST-SRX    ] 02 50 12.F5.69 03.06.92 8B 01 00           (00)
Sat 10/09/2010 02:23:16 PM : [standard-Broadcast][12.F5.69-->03.06.92] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:16 PM : [iRlinc] Start : Adding device to ISY
Sat 10/09/2010 02:23:16 PM : [iRlinc] Finish : Adding device to ISY was Successful
Sat 10/09/2010 02:23:16 PM : [12 F5 69 1  ] Link    0 : 0FF8 [E2010CA633FF1F01] Saving  [E2010CA633FF1F01]
Sat 10/09/2010 02:23:16 PM : [12 F5 69 1  ] Finding linked devices
Sat 10/09/2010 02:23:16 PM : [12 F5 69 1  ] Using engine version i1
Sat 10/09/2010 02:23:16 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:17 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:17 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:17 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B 98 06          PEEK   (98)
Sat 10/09/2010 02:23:17 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 00    PEEK   (00)
Sat 10/09/2010 02:23:17 PM : [  12 F5 69 1] Device added to ISY
Sat 10/09/2010 02:23:18 PM : ---- All Remaining Device Added ----
Sat 10/09/2010 02:23:18 PM : ---- Start: Generate Scenes from links ----
Sat 10/09/2010 02:23:35 PM : ---- End:   Generate Scenes from links ----
Sat 10/09/2010 02:23:35 PM : [12 F5 69 1  ] Using engine version i1 for 'IRlinc'
Sat 10/09/2010 02:23:35 PM : [12 F5 69 1  ] Link    0 : 0FF8 [E2010CA633FF1F01] Writing [E2010CA633FF1F01]
Sat 10/09/2010 02:23:35 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:36 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:36 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F8 06          PEEK   (F8)
Sat 10/09/2010 02:23:36 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:23:36 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 E2 06          POKE   (E2)
Sat 10/09/2010 02:23:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 E2    POKE   (E2)
Sat 10/09/2010 02:23:37 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:37 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F9 06          PEEK   (F9)
Sat 10/09/2010 02:23:37 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 01    PEEK   (01)
Sat 10/09/2010 02:23:37 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:38 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:38 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:38 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FA 06          PEEK   (FA)
Sat 10/09/2010 02:23:38 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:23:38 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:39 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:39 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:39 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FB 06          PEEK   (FB)
Sat 10/09/2010 02:23:39 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:23:39 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:40 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:40 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:40 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FC 06          PEEK   (FC)
Sat 10/09/2010 02:23:40 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:23:40 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:41 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:41 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:41 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FD 06          PEEK   (FD)
Sat 10/09/2010 02:23:41 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B FF    PEEK   (FF)
Sat 10/09/2010 02:23:41 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:42 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:42 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:42 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FE 06          PEEK   (FE)
Sat 10/09/2010 02:23:42 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 1F    PEEK   (1F)
Sat 10/09/2010 02:23:42 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:23:43 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:23:43 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:23:43 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FF 06          PEEK   (FF)
Sat 10/09/2010 02:23:43 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 01    PEEK   (01)
Sat 10/09/2010 02:23:44 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 12 F5 69 03 06 92 06
Sat 10/09/2010 02:23:44 PM : [PLM         ] Group   1 : Writing Responder Link matching [12 F5 69 1  ] Link    0 : 0FF8 [E2010CA633FF1F01]
No Good. Only 'Button A' Shows up. I remove the device again and add 'Button E' using the "Add Button to IRLinc" in Link Management:
Sat 10/09/2010 02:26:29 PM : [iNST-SRX    ] 02 50 14.07.EE 0C.A6.33 07 6E 50           (50)
Sat 10/09/2010 02:26:29 PM : [standard-Direct][14.07.EE-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sat 10/09/2010 02:26:29 PM : [   14 7 EE 1]       ST 160
Sat 10/09/2010 02:26:38 PM : [LNK-BGN     ] 02 64 00 00 06
Sat 10/09/2010 02:26:39 PM : [LNK-STAT    ] 02 53 S(00) gid=05 12.F5.69 0000 00
Sat 10/09/2010 02:26:39 PM : Linked: Linked 12.F5.69.05 type=03.06.00
Sat 10/09/2010 02:26:39 PM : [12.F5.69.5] Start : Adding device to ISY
Sat 10/09/2010 02:26:39 PM : [12.F5.69.5] Finish : Adding device to ISY was Successful
Sat 10/09/2010 02:26:40 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:26:40 PM : [  12 F5 69 5] Removing all links
Sat 10/09/2010 02:26:40 PM : [12 F5 69 5  ] Couldn't retrieve the root node for 12.F5.69.5. Reverting to i1
Sat 10/09/2010 02:26:40 PM : [12 F5 69 5  ] Using engine version i1 for '12.F5.69.5'
Sat 10/09/2010 02:26:40 PM : [LNK-END     ] 02 65 06
Sat 10/09/2010 02:26:40 PM : [standard Msg. Handler] Unexpected Ack imCmd=65 cmd1= 0x69
Sat 10/09/2010 02:26:40 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:41 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:41 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:45 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:45 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:45 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F8 06          PEEK   (F8)
Sat 10/09/2010 02:26:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B E2    PEEK   (E2)
Sat 10/09/2010 02:26:46 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:46 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:46 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:47 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:47 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F0 06          PEEK   (F0)
Sat 10/09/2010 02:26:47 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:48 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:48 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:48 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:49 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E8 06          PEEK   (E8)
Sat 10/09/2010 02:26:49 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:49 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:50 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:50 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:50 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E0 06          PEEK   (E0)
Sat 10/09/2010 02:26:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:51 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:51 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:51 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:52 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:52 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D8 06          PEEK   (D8)
Sat 10/09/2010 02:26:52 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:53 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:53 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:53 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:54 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B D0 06          PEEK   (D0)
Sat 10/09/2010 02:26:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:55 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C8 06          PEEK   (C8)
Sat 10/09/2010 02:26:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:56 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:56 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:57 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B C0 06          PEEK   (C0)
Sat 10/09/2010 02:26:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:26:58 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:58 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:26:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:26:59 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B8 06          PEEK   (B8)
Sat 10/09/2010 02:26:59 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:26:59 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:26:59 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:26:59 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:27:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:00 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:00 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B B0 06          PEEK   (B0)
Sat 10/09/2010 02:27:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:27:01 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:27:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:27:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:02 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:02 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:02 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A8 06          PEEK   (A8)
Sat 10/09/2010 02:27:02 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:27:02 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:27:03 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:27:03 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:03 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:03 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:04 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B A0 06          PEEK   (A0)
Sat 10/09/2010 02:27:04 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 62    PEEK   (62)
Sat 10/09/2010 02:27:04 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:04 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 00 06          POKE   (00)
Sat 10/09/2010 02:27:04 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 00    POKE   (00)
Sat 10/09/2010 02:27:05 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:05 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:05 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:05 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B 98 06          PEEK   (98)
Sat 10/09/2010 02:27:06 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 00    PEEK   (00)
Sat 10/09/2010 02:27:06 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:06 PM : [12 F5 69 5  ] Couldn't retrieve the root node for 12.F5.69.5. Reverting to i1
Sat 10/09/2010 02:27:06 PM : [12 F5 69 5  ] Link    0 : 0FF8 [E2050CA633FF1F05] Saving  [E2050CA633FF1F05]
Sat 10/09/2010 02:27:07 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:27:07 PM : [12 F5 69 5  ] Couldn't retrieve the root node for 12.F5.69.5. Reverting to i1
Sat 10/09/2010 02:27:07 PM : [12 F5 69 5  ] Using engine version i1 for '12.F5.69.5'
Sat 10/09/2010 02:27:07 PM : [12 F5 69 5  ] Link    0 : 0FF8 [E2050CA633FF1F05] Writing [E2050CA633FF1F05]
Sat 10/09/2010 02:27:07 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:08 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:08 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:08 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F8 06          PEEK   (F8)
Sat 10/09/2010 02:27:08 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 00    PEEK   (00)
Sat 10/09/2010 02:27:08 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 E2 06          POKE   (E2)
Sat 10/09/2010 02:27:09 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 E2    POKE   (E2)
Sat 10/09/2010 02:27:09 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:09 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B F9 06          PEEK   (F9)
Sat 10/09/2010 02:27:09 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 05    PEEK   (05)
Sat 10/09/2010 02:27:09 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:10 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:10 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:10 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FA 06          PEEK   (FA)
Sat 10/09/2010 02:27:10 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:27:10 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:11 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:11 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:11 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FB 06          PEEK   (FB)
Sat 10/09/2010 02:27:11 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:27:11 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:12 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:12 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:12 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FC 06          PEEK   (FC)
Sat 10/09/2010 02:27:12 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:27:12 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:27:13 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:27:13 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:13 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FD 06          PEEK   (FD)
Sat 10/09/2010 02:27:13 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 03    PEEK   (03)
Sat 10/09/2010 02:27:13 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 FF 06          POKE   (FF)
Sat 10/09/2010 02:27:14 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 FF    POKE   (FF)
Sat 10/09/2010 02:27:14 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:14 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FE 06          PEEK   (FE)
Sat 10/09/2010 02:27:14 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 05    PEEK   (05)
Sat 10/09/2010 02:27:14 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 1F 06          POKE   (1F)
Sat 10/09/2010 02:27:15 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 1F    POKE   (1F)
Sat 10/09/2010 02:27:15 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:15 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B FF 06          PEEK   (FF)
Sat 10/09/2010 02:27:15 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 63    PEEK   (63)
Sat 10/09/2010 02:27:15 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 05 06          POKE   (05)
Sat 10/09/2010 02:27:16 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 05    POKE   (05)
Sat 10/09/2010 02:27:16 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:27:16 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 12 F5 69 03 06 00 15
Sat 10/09/2010 02:27:16 PM : [PLM         ] Group   5 : Writing Responder Link matching [12 F5 69 5  ] Link    0 : 0FF8 [E2050CA633FF1F05]
Sat 10/09/2010 02:27:18 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:27:18 PM : ---- All Linked Devices are now initialized ----
YEAH!!! Success! Everything works as expected now for 'Button E' except it is reported as V.00 in the ISY. I do the same thing for another button:
Sat 10/09/2010 02:29:51 PM : [LNK-BGN     ] 02 64 00 00 06
Sat 10/09/2010 02:29:52 PM : [LNK-STAT    ] 02 53 S(00) gid=03 12.F5.69 0000 00
Sat 10/09/2010 02:29:52 PM : Linked: Linked 12.F5.69.03 type=03.06.00
Sat 10/09/2010 02:29:52 PM : [12.F5.69.3] Start : Adding device to ISY
Sat 10/09/2010 02:29:52 PM : [12.F5.69.3] Finish : Adding device to ISY was Successful
Sat 10/09/2010 02:29:52 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:29:52 PM : [12 F5 69 3  ] Couldn't retrieve the root node for 12.F5.69.3. Reverting to i1
Sat 10/09/2010 02:29:53 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Sat 10/09/2010 02:29:53 PM : [12 F5 69 3  ] Link    2 : 0FE8 [E2030CA633FF1F03] Saving  [E2030CA633FF1F03]
Sat 10/09/2010 02:29:53 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:29:54 PM : [12 F5 69 5  ] Couldn't retrieve the root node for 12.F5.69.5. Reverting to i1
Sat 10/09/2010 02:29:54 PM : [12 F5 69 5  ] Using engine version i1 for '12.F5.69.5'
Sat 10/09/2010 02:29:54 PM : [12 F5 69 5  ] Link    2 : 0FE8 [E2030CA633FF1F03] Writing [E2030CA633FF1F03]
Sat 10/09/2010 02:29:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:54 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:54 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E8 06          PEEK   (E8)
Sat 10/09/2010 02:29:54 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B E2    PEEK   (E2)
Sat 10/09/2010 02:29:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:55 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:55 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B E9 06          PEEK   (E9)
Sat 10/09/2010 02:29:55 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 03    PEEK   (03)
Sat 10/09/2010 02:29:56 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:56 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:56 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EA 06          PEEK   (EA)
Sat 10/09/2010 02:29:56 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 0C    PEEK   (0C)
Sat 10/09/2010 02:29:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:57 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:57 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EB 06          PEEK   (EB)
Sat 10/09/2010 02:29:57 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B A6    PEEK   (A6)
Sat 10/09/2010 02:29:58 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:58 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:58 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EC 06          PEEK   (EC)
Sat 10/09/2010 02:29:58 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 33    PEEK   (33)
Sat 10/09/2010 02:29:59 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 28 0F 06          SET-MSB(0F)
Sat 10/09/2010 02:29:59 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 28 0F    SET-MSB(0F)
Sat 10/09/2010 02:29:59 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:29:59 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B ED 06          PEEK   (ED)
Sat 10/09/2010 02:29:59 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 03    PEEK   (03)
Sat 10/09/2010 02:30:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 FF 06          POKE   (FF)
Sat 10/09/2010 02:30:00 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 FF    POKE   (FF)
Sat 10/09/2010 02:30:00 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:30:00 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EE 06          PEEK   (EE)
Sat 10/09/2010 02:30:00 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 05    PEEK   (05)
Sat 10/09/2010 02:30:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 1F 06          POKE   (1F)
Sat 10/09/2010 02:30:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 1F    POKE   (1F)
Sat 10/09/2010 02:30:01 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:30:01 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 2B EF 06          PEEK   (EF)
Sat 10/09/2010 02:30:01 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 2B 63    PEEK   (63)
Sat 10/09/2010 02:30:02 PM : [iNST-ACK    ] 02 62 12.F5.69 0F 29 03 06          POKE   (03)
Sat 10/09/2010 02:30:02 PM : [iNST-SRX    ] 02 50 12.F5.69 0C.A6.33 2B 29 03    POKE   (03)
Sat 10/09/2010 02:30:02 PM : [standard-Direct Ack][12.F5.69-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 10/09/2010 02:30:02 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 12 F5 69 03 06 00 15
Sat 10/09/2010 02:30:02 PM : [PLM         ] Group   3 : Writing Responder Link matching [12 F5 69 5  ] Link    2 : 0FE8 [E2030CA633FF1F03]
Sat 10/09/2010 02:30:04 PM : ---- Initializing the linked devices ----
Sat 10/09/2010 02:30:04 PM : ---- All Linked Devices are now initialized ----
Sat 10/09/2010 02:30:16 PM : [iNST-SRX    ] 02 50 14.07.EE 0C.A6.33 07 6E 4F           (4F)
Sat 10/09/2010 02:30:16 PM : [standard-Direct][14.07.EE-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sat 10/09/2010 02:30:16 PM : [   14 7 EE 1]       ST 158
And Failure!!. So I can add one button to this device, and every method I use to try to add another button fails. It shows up in the device tree, I can add it to scenes, it will control those scenes, but without the ISY aware of its presence. So no status updates on devices, no ability to use stuff in programs etc...
Looks like it is a PLM issue. I did a restore PLM and then was able to add 2 buttons. I guess I have hit my links limit with this PLM. Sorry for the long winded post that appears at this point to have nothing whatsoever with any of the info I posted.
      378.3k
