Fast On/Off
Since upgrading to the latest firmware my ISY will not recognize the double tap of my dimmers and switches.
ie IF Control Dining Fast On
Even the event log does not display anything when I double tap the switch.
Has anyone else experienced this?
If the event is not traced likely not being seen by the PLM. What if you do a simple single tap, does that show in the event viewer trace. Be sure to set Change Level 3.
Sounds like the PLM link records may have been lost for some reason if multiple devices have the same problem. If single tap does not show up try restoring the PLM link database.
Thanks again Lee
I restored the PLM and I now get events for all my switches except for the two new Dual Band Dimmers I've recently installed.
