Repeat?
Is it possible to do this?
status 'lamp' is on
Repeat 5 times
lamp beep
wait 2 seconds
set 'light' on
else
What I'm trying to ask is it possible to have an action after the repeat command that doen't repeat? So in this case it would beep 5 times then turn on a light.
Try something like this:
       Control 'Light' is switched On
       Repeat 5 times
          Set 'Different Light' 1 (Beep Duration)
       Repeat 1 times
          Set 'Light' Off
I find the beep duration of 1 will occasionally give a double-beep the first time, so don't set two different programs to indicate different things with just 1 difference in beep count!
The second Repeat ends the loop. If there's no second Repeat, all instructions through the end of the program repeat.
When you are in the Administrative Console, you can always click on Help... UDI Wiki, then search for a keyword like Repeat. There's tons of great reference info there.
