Toggle Off and Status
Is it possible to have an 8 button KPL with button 7 set to toggle off and yet still show the status (in other words, light up) when the linked light is turned on?
A program?
CopyRon
Depends on the firmware level of the KPL (I do not know the exact firmware level where it changed).
Older KPLs used the On/Off state of the LED to control whether the button press resulted in non-toggle On mode or non-toggle Off mode. Later KPLs maintain the non-toggle mode state in internal memory which is not affected by whether the LED is On or not.
If you have newer KPLs it will likely work.
Lee
I do this. I have a KPL button set to non-toggle off, but make it a responder in a scene with another device who's status I want to know. It turns on and off, based on the status of the other device.
I assume, based on LeeG's response, that mine is a newer KPL.
I had just replaced this KPL with V.36 because thr older one could not do this.
After about an hour, the new KPL started responding as I expected.
